Urgent Wire Help
Old Mar 2, 2011 | 05:55 PM
abelmoreno's Avatar
abelmoreno
Urgent Wire Help
Hi,
I was changing #6 spark plug on a 4.9 300 and accidentally seem to have disconnected a Ground cable that is connected to one of the bolts at the wiper motor. It is about 1 1/2 feet long and is about 10 gauge and is black. Where does the other end connect??
Wiper motor is working fine which is where I thought this was connected to. Truck does not start and I don't know if this is why!
Cheers,
Abel
Old Mar 2, 2011 | 06:16 PM
DBGrif91's Avatar
DBGrif91
I can't offer you any immediate help, but if you have any way to post a picture, that could help us figure it out. Even if it's only of the area where you think it broke loose.
Old Mar 3, 2011 | 04:35 AM
TexasGuy001's Avatar
TexasGuy001
Its really hard to say where it goes with out seeing it.
Old Mar 3, 2011 | 06:45 AM
hav24wheel's Avatar
hav24wheel
A pic will clear this up I'm sure.
Old Mar 13, 2011 | 12:23 AM
abelmoreno's Avatar
abelmoreno
Right... I finally found the original location of this wire, which reads Ford all along.
It goes from one of the bolts on the wiper motor base to the engine block right above the oil pan on the driver's side. The socket was still on the block but the wire had been pulled, surely when the body was lifted.
Thanks
Abel
Old Mar 13, 2011 | 09:59 AM
dustybumpers's Avatar
dustybumpers
that wire is the body ground, not all the trucks had it, and there is a TSB, to add it.
Old Mar 13, 2011 | 03:20 PM
abelmoreno's Avatar
abelmoreno
The body ground on my truck goes from the manifold to the firewall and this wire is braided and silver.
This wire seems to be an additional ground from the engine to the wiper motor area. But you guys are the experts.
Cheers
Old Mar 13, 2011 | 04:41 PM
73FOMO's Avatar
73FOMO
The body ground should have nothing to with the motor starting. Why did you change one spark plug? What were your issues?
Old Mar 13, 2011 | 08:51 PM
abelmoreno's Avatar
abelmoreno
The engine had been missing throughout driving speed range and I figured it might have been an ignition issue, which it was. I checked the cables and #6 was having trouble (you could see its current on the outside in the dark), swapped the cable and problem persisted, so I decided to change #6 spark plug. Once I did this, the truck started and the engine ran well, it was not missing anymore, but now it ran at extremely low RPM ... and then after starting it again, it died. I cleared my head and a couple of days later I decided to get under the truck and found this new problem (coincidence... go figure) the fuel pump cable was disconnected. Once I plugged it back in, truck ran like a charm... It's been over a week now and it is running perfectly!.
Abel
macbuz
23
Dec 8, 2014 06:16 AM
78f150dent
Sep 23, 2011 12:20 AM
kidoo
13
Mar 15, 2007 10:34 AM
krautwolf
Nov 6, 2005 11:57 AM
texasbob
May 12, 2002 08:51 PM
