1989 f250 4x4
#31
Received 3,178 Likes
on
#33
ok, the truck is running at 180 degrees the fast idle spring is turned all the way out, the two adjusters on the front of the carb are turned almost all the way in. the choke is wide open, truck still running way high it came down a little but not much, and it smells like its burning a lot of gas..
do i need to let it run for a while? or should i start checking for vacuum leaks? if so whats the best way to go about that i live in a old people neighborhood and they are not happy about a 351 with custom exhaust screaming at 2000 rpm all morning
#34
#35
#36
#37
#38
Yeah i read through the manual you linked for me, and set the adjustments to factory but that was no help, it's gonna be something internal like the needle you talked about. I'm going to reference the manual you linked to see how to check the pressure i don't have a pressure gauge if one is needed.
#40
#41
YESSSSSSSSSSSSSSSS................. I think i fixed the carb not sure though, Ive been all over that thing the bolts that connect the carb to the intake were loose? but that wasn't it i think it was a little bracket on the side where the throttle cable is, it was all the way up i pushed it down a couple notches and its idling like a dream,(compared to 2000rpm)
before i drive it though i have to figure my starter out but that manual came in very helpful i'm gonna save that to my comp.
Leftwardpie
16
04-20-2024 03:57 PM
RotGrubestier44
13
11-20-2012 09:45 AM
