What size wires on dual battery system?
Need to replace some terminals due to corrosion and want to make sure they are big enough. Was planning on using some audio type terminal clamps with set screw or compression connections but wnated to know how big the holes needed to be. I can't find any writing on the OEM cables but the negative looks pretty large. Don't want to order something and then have the wire not fit the hole.
Thanks,
Eric
Thanks,
Eric
