1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
What size wires on dual battery system?
Old 03-01-2011, 02:08 PM
busflyer's Avatar
busflyer
busflyer is offline
Need to replace some terminals due to corrosion and want to make sure they are big enough. Was planning on using some audio type terminal clamps with set screw or compression connections but wnated to know how big the holes needed to be. I can't find any writing on the OEM cables but the negative looks pretty large. Don't want to order something and then have the wire not fit the hole.
Thanks,
Eric
