302 intake upgrades
Old Mar 1, 2011 | 10:55 AM
loseboltssinkships's Avatar
loseboltssinkships
302 intake upgrades
i was gonna upgrade my intake i found this manifold Edelbrock 3841 - Edelbrock Performer 5.0 EFI Truck Intake Manifolds - Overview - SummitRacing.com
i wanted to know if i should get a new throttle body or keep the same one ..if i do get a new one which diameter?
Old Mar 1, 2011 | 01:46 PM
lew52's Avatar
lew52
I guess your going to build the motor , with the edelbrock truck intake i would use the duel 61mm TB .....Lew
Old Mar 1, 2011 | 02:23 PM
rla2005's Avatar
rla2005
The factory 5.0L truck intake is pretty decent as it is. What exactly are your plans for the rest of the engine?
Old Mar 1, 2011 | 05:09 PM
Conanski's Avatar
Conanski
You're wasting your money here, the stock truck intake flows at least as much as the Edelbrock and the existing throttlebodies also flow enough to support about 400hp, so unless your motor is heavily modified this change won't accomplish anything.
Old Mar 1, 2011 | 06:09 PM
lew52's Avatar
lew52
Im with the others , unless your building up your motor , the stock intake is fine , i use the eddey truck intake and its good , but won't help much with stock heads and cam , so if you don't allready have that then spend the money on exhaust , cam , heads , gears , then if you get to the point you need more air , it will help alot to open up the intake....
Old Mar 2, 2011 | 03:59 AM
TexasGuy001's Avatar
TexasGuy001
I'm also going to say stick with the truck 5.0 intake.
Old Mar 2, 2011 | 04:24 AM
96F150EB's Avatar
96F150EB
I agree with what he said. I too was tempted to buy the Edelbrock manifold too, until a realized there wasn't much gain in just adding it. There are other ways to wisely spend your money. I suggest getting the E-fans if you haven't already. That will be my purchase after I'm done with the interior project I'm currently working on.
mattt181
Ford Truck Parts for Sale
Aug 26, 2016 12:42 AM
jpeckham
Jan 20, 2013 12:52 PM
shorty2tall
May 15, 2012 09:54 PM
Tech-man
Apr 3, 2011 08:54 AM
TheTowingCowboy
19
Oct 23, 2007 08:29 PM
