Exterior temp sensor.
Old Feb 28, 2011 | 11:03 PM
BigLouEx's Avatar
BigLouEx
Anyone know where the exterior temp sensor is located? Trying to track down why mine is reading incorrectly.
Old Mar 1, 2011 | 02:01 AM
wallz's Avatar
wallz
Should be just to the side of driver headlight behind grill. Kinda where people cut in extra holes for intake. (zoodad) mod
Old Mar 1, 2011 | 07:57 AM
MoreBoostPlease's Avatar
MoreBoostPlease
Which display does that feed? The temp on my climate control screen is correct however, the overhead display temp is not. (it's a constant -40)
Old Mar 1, 2011 | 09:26 AM
RMBC Freeride's Avatar
RMBC Freeride
Here is a good thread about the -40 overhead. My guess is that your overhead display was replaced at some point with one from a truck that did not have the display on the AC unit. You should not have both. (my X is the same way)
https://www.ford-trucks.com/forums/1...light=overhead
Old Mar 1, 2011 | 09:31 AM
MoreBoostPlease
Thanks! Now I won't try to "fix" it. lol
Old Mar 1, 2011 | 01:47 PM
BigLouEx's Avatar
BigLouEx
Thanks for the help. I only have one display on the overhead. Getting inaccurate readings. I will start at the sensor and work my way back and try and find the problem.
Old Mar 1, 2011 | 05:10 PM
BigLouEx's Avatar
BigLouEx
OK found small black cube behind grille on drivers side (approx. 1 inch square) with three wires coming out of it. Is this the temp sensor?
johnkn
2015 + Expedition & Navigator
Jun 27, 2015 02:25 PM
cooljman1
1997 - 2003 F150
Jan 27, 2014 07:25 AM
mmenzies
Nov 7, 2013 12:42 PM
oldmerc
Sep 15, 2013 07:21 PM
2 cowpokes
Aug 10, 2013 11:07 PM
