Connecticut Chapter Join Chapter, Leader:
CT Chapter March B/S Thread
Old Mar 30, 2011 | 08:47 PM
  #1066
Canned Ham 450's Avatar
Canned Ham 450
Originally Posted by Zookie400
no piston yet. i need to decide what size bore i want to run. its going to be around $250 for a custom piston for 96mm bore which is what i want. i could just run the 94mm jug with an off the shelf piston just to get it running. i also need to get threaded bungs and rod ends for my subframe.
i thought you ordered a 97mm gasket? doesnt that mean thats what you need to run?
Old Mar 30, 2011 | 08:55 PM
  #1067
acf6's Avatar
acf6
he probably is
Old Mar 30, 2011 | 09:01 PM
  #1068
Zookie400's Avatar
Zookie400
i dont think i can fit a 97mm in my jug. and it would cost about $400 for a custom batch of pistons (minimum order of 4 from CP)
gasket choices are stock 94mm (stock bore is 90mm) or oversized 97mm. the gasket is always bigger than the piston.
Old Mar 30, 2011 | 09:02 PM
  #1069
StreamlineGT's Avatar
StreamlineGT
Miles, you need my touchtek switches with custom mounting bracket i made.
Old Mar 30, 2011 | 09:04 PM
  #1070
acf6's Avatar
acf6
do you have any pictures ?
Old Mar 30, 2011 | 09:32 PM
  #1071
7.3 Rocket's Avatar
7.3 Rocket
Originally Posted by Towmanjbo
Hey anybody got a good used battery? I need one for the '83 so it'll stay running, I can give it back after a month or so while Josiah and I swap parts, that way I can move it around if need be. I can buy one at the junk yard for $25 but I don't want to spend anymore money on it.
I have a spare battery you can use.
Aaron, no plow wax. Didn't even hook it up yet.
Spent today b@stardizing my fuel fill to make it work with the flatbed. And picking up my new pair of glasses. Old pair split directly down the middle.
  #1072
Canned Ham 450
i dont think you want to go any bigger than whats already in there unless you get an athena cylinder. Your walls will be too thin if you punch it out that big and it will crumble. id stick with a 94 or 95
Old Mar 30, 2011 | 09:40 PM
  #1073
Zookie400's Avatar
Zookie400
i have 2 jugs, one is steel sleeved to 95.5, the other is only a 93 or 94 but its an athena style aluminum nikasil'd one, i think its cylinderworks brand. those can be bored to 96 max. anything after that and i need the $1000 ice cube to bore into.
Old Mar 31, 2011 | 12:46 AM
  #1074
Menghi08LT's Avatar
Menghi08LT
Personally I'm hoping for no snow. With the sounds of it with rain it's just gonna be a mess here... Not like it'll stick anyway, the three driveways I'd hit all have sand on them still. Hooking up is no problem though, I still have to figure out some form of ballast...
Old Mar 31, 2011 | 03:44 AM
  #1075
Towmanjbo's Avatar
Towmanjbo
miles- we can always custom fab you a switch panel, if you can draw it we can build it. i know someone with a plasma cutter, welder, drill press, and powdercoater.
I say use one of Aarons' aluminum diamond plate mudflaps as a starting point. Cut, bend, and drill holes and polish Voila a custom switch panel
Old Mar 31, 2011 | 03:48 AM
  #1076
Towmanjbo's Avatar
Towmanjbo
Cool Thanks
Old Mar 31, 2011 | 03:52 AM
  #1077
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Good morning Justin and the rest of the morning crew!
I don't want to be out in the rain.
Old Mar 31, 2011 | 04:21 AM
  #1078
gbroehl1's Avatar
gbroehl1
Good morning everyone. I'm very sore right now and of course had to spend part of my evening last night covering the dumpster up with tarps so that I'm not spending any more money than I have to.
Old Mar 31, 2011 | 04:24 AM
  #1079
rocdril's Avatar
rocdril
Morning everyone, is it raining in CT?
Old Mar 31, 2011 | 04:27 AM
  #1080
gbroehl1's Avatar
gbroehl1
No rain yet.
