What Headers Do You Run?
Old Feb 28, 2011 | 08:52 PM
cliffordingles's Avatar
cliffordingles
So LMC offer the wrong headers for my truck. 86 f250 HD 4x4.
What Headers do you run on your truck? thanks!
Old Feb 28, 2011 | 09:09 PM
glovemeister's Avatar
glovemeister
Hedman or Hookers is what I've been hearing. I actually was not planning on the headers because I had a buddy tell me every week in high school after class on Friday (this is the early eighties) he would have to torque down his header bolts, and head out the pickup some girls haha. I like all the aspects put I've been told that with new heads, intake manifold, headers, straight up timing, cam, roller tchain with +4 advanced=0* timing my truck will be quite a screamer. Especially so with the holley 950 and overdrive unit.
Old Feb 28, 2011 | 09:22 PM
ebodell's Avatar
ebodell
I have run Doug Thorley (sp?) headers before. It was on a big block so the mileage really only increased by ~0.5 mile/gallon. It did help the engine breath and seemed to give it a bit more on the bottom end. That was some time ago so it may have been more perception than reality (the increased exhaust noise seemed to play tricks on my early twenties brain). As for re-torquing them I typically just put a wrench on them at every oil change and called it good.
Old Feb 28, 2011 | 09:48 PM
Shark Racer's Avatar
Shark Racer
Headers really woke my 78 vette up, knocked half a second off my 0-60 time.
If I can get an extra 1/2mpg out of my 460, the headers would be totally worth it.
Old Feb 28, 2011 | 09:53 PM
glovemeister
I'm starting to think so also SR. I was vehemently against them, but now I am starting to think it might be a good choice. I'd do it if the torquing was infrequent.
Old Feb 28, 2011 | 10:40 PM
cliffordingles
im looking to see what people are running on their trucks and how they fit. i need a set real soon since the ones i ordered from LMC dont fit right.
Old Mar 1, 2011 | 04:08 AM
fordman75's Avatar
fordman75
If you don't want to constantly re-torque the header bolts. Then invest in a set of "Stage 8" locking header bolts.
My 84 F250 4x4 came with some standard Hedman headers that some idiot cut off the collectors and welded the exhaust system directly to them.
I'm going to replace them with a pair of Hedman Elite headers. I've always been happy with their quality and fit of their headers.
Old Mar 1, 2011 | 09:30 PM
cliffordingles
well the set i have on the truck now are hedman, they dont fit. drivers side is WAY to close to the drive line. im gunna try and order a new set tonight and i hope LMC will take these one back.
Old Mar 1, 2011 | 09:35 PM
fordman75's Avatar
fordman75
Does your truck still have the TTB? Or does your truck have a D60 swapped in? Because the Hedman headers had a foot note saying they won't fit with a D60.
Old Mar 1, 2011 | 09:40 PM
cliffordingles
its still TTB. the set i have are for my model. but dont fit. im searching for a new set now...
Old Mar 1, 2011 | 10:02 PM
fordman75's Avatar
fordman75
That's weird. If you are sure you've got the correct ones for your model truck, engine size and 4wd then they should fit. If you somehow ended up with 302 or 2wd headers then they might not.
Do you happen to have the part# for the set you've got? I believe the ones for your truck are the part # 89270.
Here's a pic of how my old ones fit before I tore the truck down. Not the best picture but it shows there's plenty of room for the driveshaft.
Old Mar 2, 2011 | 01:03 PM
spurredon's Avatar
spurredon
Fordman, your headers look fine as far as space from the driveshaft, but the pic that Clifford posted on another thread show the collector almost touching the drive shaft.
I plan on putting headers on my 86' F250 4x4 351W, but when I saw the trouble that Clifford had with the Hedman #89270's, I decided to wait and see how he makes out with his first. It is possible that LMC sent him some bad ones. Thanks for being the test pilot Clifford!
Old Mar 2, 2011 | 02:09 PM
cliffordingles
yea, i called LMC customer service today, they said i can send them back for a refund. so im gunna do that and order some new ones today. prolly gunna get Flowtech. i heard they sit low on our trucks but i have a 4 inch lift so i dont see that being a problem.
Old Mar 2, 2011 | 03:51 PM
Diesel_Brad's Avatar
Diesel_Brad
look up L&L. I am runnin them on my pulling truck for over 15 years and have not replaced one gasket
here is a link to ones to fit your truck http://www.landlproducts.com/details...17&ItemID=1098 not cheap but worth the money
Old Mar 2, 2011 | 08:54 PM
cliffordingles
lol, damn those are spendy. not wanting to spend that much for headers right now...
can anyone tell me about more about the Flowtechs?only problem ive heard is they hang low.
