76 360 timeing issue
Old Feb 28, 2011 | 07:27 PM
supercabfreak's Avatar
supercabfreak
ive got a 76 f350 with a 360. the issue im haveing is with the ignition timeing. ive been told that my dizzy should be set somewhere between 6-8 degrees atdc. when i set it at 8 degrees atdc it backfires under acceleration, doesnt have much power, and smells horrificly rich. to get her to run right im keeping it timed between 0tdc and 2 degrees atdc any help is much appreciated.
im running stock duraspark ign. and an autolite 4100 4bbl
Old Feb 28, 2011 | 08:30 PM
mustang_gt_350's Avatar
mustang_gt_350
I would say you want it BTDC not AFTC. Have you tried setting it anything more advanced than 0? I would guess its a MAJOR dog with the timing set at that.
Old Feb 28, 2011 | 09:27 PM
Death85e's Avatar
Death85e
You definately want to time it before top dead center not after. A good starting point is 6 degrees BTDC then tune it from there.
Old Mar 1, 2011 | 07:09 PM
supercabfreak
sorry guys i goofed up i am timeing it btdc it becomes evil atdc and at 2-3 degrees btdc it is a dog but if i advance it on up to 6 degrees or so it backfires and hickups
Old Mar 2, 2011 | 09:34 AM
mustang_gt_350
Is this a freshly built engine? or are you just playing with the timing?
Old Mar 2, 2011 | 10:07 PM
supercabfreak
i bought this truck a lil over a year ago the PO told me it was a 390 that had been recently warmed over (obviously but the rtv mashed out around the intake )
i learned that all 360s magicly become 390's on sale day and i have every reason to beleive it IS a 360 based on vin and data decodes
the carb was rebuilt back in dec. it got new plugs, wires, dizzy cap, rotor button, new ignition module, coil, distributor and engine harness
ive had the same set of semptoms since i bought it......depending on what i do/change makes it better or worse
Old Mar 2, 2011 | 11:03 PM
Sleepy445FE's Avatar
Sleepy445FE
well there is an easy way to measure the stroke to know what you have. Just pull a spark plug and put a dowel in and rotate crank. Make a mark at tdc and bdc on the dowel and measure the difference. 3.5" = 352/360, 3.78" = 390
doesnt change anything about your timing issue but you'll at least know your cid, ffr.
Old Mar 3, 2011 | 01:53 AM
Redmanbob's Avatar
Redmanbob
Regardless of CI displacement the timing concerns are the same, unless "warmed over/put together incorrectly/etc.."
Start fresh, assume the PO was an entire ***.
bring it to TDC comp stroke, verify TDC of piston and 0 alignment balancer.
Check distributor's rotor position, rotor should be pointed at rear of engine. Moving plug wires is an option, you choose. Correct way, pull distr and correct error if found. Good/Alignment corrected, check firing order of wires (counter clockwise (see intake for sequence if stumped). Correct any errors. Remove vac line from dist and plug off. Start engine, let warm to norm op temp and review timing mark at correct idle speed (auto trans wheels chocked , ebrake on, in gear) set to 8-10º BTDC.
Old Mar 3, 2011 | 06:51 PM
supercabfreak
worked on it a little today and found that the vacume advance is inconsistant....thus explains random setting changes.
i removed the vacume line from the advance and timed it at 10 degress btdc, pluged the advance back it and watched the timeing advance itself close to 2 degrees............normal right? or so i was told
i took her out and drove 2-3 miles of "average" driveing some hard some easy broght it back and threw the timeing ligt on and saw that the advance wasnt advanceing the spark when i pluged it in.
re-seting the timeing fixed almost all of my problems but now i need to figure out why the vacume advance is randomly changeing at idle?
Old Mar 3, 2011 | 07:24 PM
69cj's Avatar
69cj
Change the vacum advance unit. Speed shop here will then set you dist. curve up for 25 bucks.
Old Mar 3, 2011 | 07:42 PM
arctic y block's Avatar
arctic y block
Is the vac advance plugged into the carb or manifold? It should be on the carb. I would also look for vacuum leaks. The FE intake is known for vacuum leaks.
Old Mar 3, 2011 | 08:08 PM
supercabfreak
yes arctic the vacume advance is plugged into the carb and im pulling 15-20 inches of vacume from the advance port
Old Mar 3, 2011 | 08:32 PM
Redmanbob's Avatar
Redmanbob
If the carb is setup correctly and idle is correct there will be no advance at idle.
Hence there should be no change when the vac line is reconnected.
As for the timing moving 8º in reverse when connecting the vac line back up. Sounds like you typoed or ? Are you disconnecting vac line while dist is loose making these timing changes and reconnecting the ac line while dist is loose? It's likely moving when you attach the hose..??? the more I read this either you are confused as to ATDC/BTDC or you have some seriously odd shiate going on. A pict or two would help all of us understand where you are at on this.
JMO
Old Mar 3, 2011 | 08:48 PM
arctic y block
Well put Bob. Thank You.
abyars111
Oct 4, 2014 06:57 PM
myoldvan
Jan 6, 2014 11:10 PM
119er
Aug 7, 2013 06:58 PM
84respass
Oct 5, 2010 10:09 PM
daddyswheels
Sep 19, 2003 11:13 PM
