hi i have a 94 F350 with the 351W, and i have to do the left side manifold. i know these are a pain in the *** to do, and i was wondering if anyone had any tips on what to do so i dont break anything.
you can heat them up if u have enough room. i wouldnt just cause it is so tight in there, but thats on my f150.. not sure how much room the 1 tons have
While PB Blaster is good stuff, Kroil is 25X better, especially on this kind of job. Spray it on a week before you start, every day, drive it and on the last day, they'll come out without any fear of breakage. If they DO break, they can be a royal PIA to extract. Don't merely soak them the night before-you WILL end up breaking some/all of them. Trust me, do the soaking every day, over a week and you'll be fine. BTW, this stuff works wonders on stuck spark plugs, which can be even worse than manifold bolts!
Roger
Roger
Remove the tire and inner fender to get good access. Use an air chisel with a blunt end and hit them straight on. I got 13 of them out by hand after doing so the other three snapped I drilled and tapped one and left one snapped off and left my tap snapped off in the second (this was last fall) no leaks. i had to make this wrench to get to the bolts near the firewall after I put my headers on
I sprayed PB Blaster for about a week before and went and did a few errands on the day I did the job so everything was good and hot. It kinda sucks to work on a motor when its hot but I don't have a torch and I didn't break any of the bolts. Just take your time, and clean up the threads with a tap before you reinstall the manifolds.
