history of f-250 TTB
Old 02-28-2011, 06:57 PM
dixiestripes351
dixiestripes351 is offline
dixiestripes351 is starting off with a positive reputation.
im trying to figure out when ford started the twin traction beam front end on the f-250. how many years in the 90s did they use it and what years. im lookin for a f-250 between 90-97 but dont want the TTB. thanks
Old 02-28-2011, 07:10 PM
fordman75
fordman75 is offline
fordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to behold
80-97HD all F250 4x4's are TTB. If you want an F250 without a TTB you'll need a 79 or older or a newer Superduty. Otherwise you are stuck swapping in a D60 out of a F350 4x4.
Old 03-01-2011, 03:13 PM
dixiestripes351
thanks so the f350 have solid axles
Old 03-01-2011, 03:42 PM
fordman75
Yes 86-97HD F350 4x4's have the Dana 60. 86-91 have the king pin D60. 92-97hd have the ball joint D60.
Old 03-01-2011, 06:31 PM
dixiestripes351
sorry i am new to the diesel world but im confused on what the difference is between those two diffs and a solid axle. the solid axles im use too are mounted with leaf springs. just tryin to learn as much as possible
Old 03-01-2011, 07:07 PM
fordman75
The diffs are the same between gas trucks and diesels.
The Dana 60 is the solid front axle. What I mentioned are just two different versions of it. It's just the way steering knuckles are connected to the axle housing. The king pin version is stronger then the ball joint version.
Old 03-02-2011, 10:25 AM
dixiestripes351
o ok i gotchya thanks for the info
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
