something is getting wet under my hood
any ideas on what my problem is? every now and then when i go through mud puddles something under my hood is getting wet and it boggs out my truck. then it kills my battery and i got to give it a day to dry out before i can jump my truck!
i heard the best way to seal up electrical componets is to spray liquid electrical tape on them...is that true?
If I was real serious, I'd get a spray bottle and hit things/connections/wires one at a time until it died.
Kinda the same with hot/cold problems.
Hair dryer and compressed air combo works great for the ignition unit in the distributor.
Heat it up, it croaks, cool it off it works...
makes it easier to justify buying a new one.
Liquid tape will seal it, as long as you want a real hassel trying to get connectors open again if it doesn't work. There are various ways to seal connectors, but the best way is to try an locate which electrical connection is causing the problem. Start with the basics and check all major connections by taking them apart and checking for corrosion and moisture. Clean the connectors and reseal with dielectric grease. Spray down all wires with a moisture displacing electrically rated lube like LPS. They make various grades of sprays depending on your needs. It will take some work if you want to do it right.
sorg76F250
08-16-2013 08:50 PM
