Sponsored by: Real Truck
OEM Keyless Entry
Old Feb 27, 2011 | 02:17 PM
Great White 350's Avatar
Great White 350
OEM Keyless Entry
I have a 2002 Ford F-350 XLT 7.3L Super Crew built with power locks but without factory keyless entry. I found this out after I bought it, I bought new key fobs only to find out after I tried to program them. Can I buy and install a new VSM and program the new key fobs. The part number I was given is 4C7Z-15604-AC. Is this correct? Is it just a plug and play application or will there be additional programing involved? I've priced them out at arount $110.00 which is great. I really want to go with an oem setup. Any help, ie part numbers, parts dealers, pics, diagrams, instructions or how to's would be greatly appreciated. Thank you for your time.
Old Feb 27, 2011 | 03:33 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
On my 05, all I had to do was have the dealer re-program the computer.
Old Feb 27, 2011 | 09:34 PM
Great White 350
Thanks for the reply. So did you just reprogram a new VSM, or reprogram the existing GEM or PCM? Thanks for your time
Old Feb 27, 2011 | 10:18 PM
dchamberlain's Avatar
dchamberlain
Does the 2002 have a GEM? If so, that's what needs to be changed or programmed. The GEM used to do all that stuff. At some point, it was eliminated and replaced with more purpose specific modules, like the VSM, 4WD control module, etc. I believe that was 2003, but I'm not sure.
eman588G
Sep 25, 2016 09:18 PM
ford_husker
Large Truck
Jul 9, 2010 10:28 AM
jfmaz
Dec 23, 2009 09:34 AM
Pocketchange5
Aug 29, 2005 08:34 PM
