71 250 CUSTOM HELP
Old Feb 27, 2011 | 01:23 PM
ZMAN1972's Avatar
ZMAN1972
71 250 CUSTOM HELP
Just bought this beast. Lot of problems including turning over and not starting. I'm starting with checking the idle cause it is idling low, but need suggestions where to go from there. Truck is missing a lot and first time with an older truck...help please.
Old Feb 27, 2011 | 01:36 PM
JeffsF-250's Avatar
JeffsF-250
Mechanic
Fuel, air, spark. If it turns over 'normally' but won't start then I would begin at the distributor (points) and work down towards the plugs to make sure you have good, consistent spark. Weak coil or bad points?
If spark is good then I would check fuel flow - maybe a shot of 'quick start' into the carb - to see if the fuel pump/filter needs further checking.
If it turns over slow then the battery/starter would be the place to start. Bad grounds can give us fits on older vehicles, run a jumper cable from the starter housing to a good chassis ground and see if it turns over better.
If it's been sitting for a while before you got it then it could be varnish/gunk in carb causing hard starting and poor idle. Sometimes a thorough dousing with carb cleaner spray will help. I'd prop the chokeplate open, spray a half can in and on the carb then leave it sit for a half hour or so before trying to start it up again.
Old Feb 27, 2011 | 01:55 PM
ZMAN1972's Avatar
ZMAN1972
Thumbs up
right on will try carb cleaner first I just had a feeling it had to do with that truck has been sitting for a while so...
Old Feb 27, 2011 | 03:56 PM
Ask92's Avatar
Ask92
Is it timed properly?
jetedwards
Oct 23, 2014 04:08 AM
Zeropowerstroke99
Apr 12, 2014 12:49 PM
Chickenguts
1983 - 2012 Ranger & B-Series
Jan 3, 2013 07:22 PM
MichaelGilliam
May 26, 2011 03:05 AM
007bronco
Alternative Fuels, Hybrids & Mileage
Dec 9, 2004 02:18 AM
