spider removed now I need help
Old Feb 26, 2011 | 12:17 PM
Liquid10Rider's Avatar
Liquid10Rider
Hey guys Im in the process of changing out the ic boots and installing the plenum inserts and didnt realize there was an oring on the spider to the turbo. the oring isnt swollen or broken or anything. is it alright to reuse the oring? and the clamp that holds it all together im guessing when i put it all back together just make sure its nice and tight? theres no torque or anything right?
Thank you,
-AJ
Old Feb 26, 2011 | 12:19 PM
timmyboy76's Avatar
timmyboy76
not sure about "torq" specs, but i'd just tighten the heck outta it, but careful though, can strip it. As for the o-ring, i re-used mine.
Old Feb 26, 2011 | 12:22 PM
Liquid10Rider
thanks for the help! I figured as much with the clamp and yeah i have done that at my job a few times with those worm clamps just wanted to make sure there wasnt some torque for it hidden somewhere ahha thanks again
Old Feb 26, 2011 | 12:23 PM
duck fan's Avatar
duck fan
Because racetruck
As long as the oring isn't pinched or anything, its good to reuse. Make sure the turbo outlet is square to the spider and you are all set.
Old Feb 26, 2011 | 12:31 PM
Liquid10Rider
well instead of having to post a new thread I just recently did the foil delete and noticed there was a small pad like of woven material. I noticed that the dent in the pipe is for a bolt if im not mistaken for the PS pump. Do you ahve to put anything in that area like the woven material?
Old Feb 26, 2011 | 12:47 PM
timmyboy76's Avatar
timmyboy76
i didnt, seems to clear it, not have issue...
Old Feb 26, 2011 | 01:36 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
once you tighten the boot clamps down they will gold the pipe in place. just center it up and tighten.....
Old Feb 26, 2011 | 02:38 PM
PaysonPSD's Avatar
PaysonPSD
Tighten the clamp for the spider to turbo connection before you tighten the boot clamps below.
Makes it easier to line up the spider with the turbo.
Punisher29073
Sep 11, 2014 07:24 PM
A/Ox4
Aug 30, 2011 11:16 PM
99StrokeXLT
Mar 5, 2011 12:15 PM
Hillcapper
Mar 28, 2009 08:46 PM
77f250highboy390
19
Jul 11, 2005 05:21 AM
