fueling problem
Old Feb 26, 2011 | 07:06 AM
chucknmesa's Avatar
chucknmesa
fueling problem
I drive an 2008 E150 for work. I ran the fuel low to the extent of bringing on the low fuel light. Had to drive about 10 miles to the first gas station. When I started to fuel the vehicle, the pump filler nozzle keeps popping off. Now I have to constantly hold the filler nozzle at barely a trickle to fuel the vehicle. In addition, the check engine light is on. Is there something that I can do to resolve the issue, or does this problem require a visit to the mechanic. Seems like the fuel tank is not venting.
Old Feb 26, 2011 | 09:04 AM
Greg B's Avatar
Greg B
Get a code scan done to see what's going on. It probably is a venting issue or canister purge valve issue.
Old Feb 26, 2011 | 11:29 AM
Wilber15's Avatar
Wilber15
Might have a plugged vent not allowing pressure that is building within the tank to vent out the filler nozzle.
Old Feb 26, 2011 | 11:33 AM
2Fords1Jeep's Avatar
2Fords1Jeep
Probably debris in the vent line. Mine was clogged with spider webs and had the same problem you describe.
pdleonard
Sep 1, 2014 03:26 PM
Neil_E.
Mar 30, 2009 07:14 PM
Dsl Lover
Oct 24, 2006 02:01 PM
nlemerise
May 7, 2006 12:22 PM
aklim
Feb 24, 2006 01:34 AM
