modified b code ?
Old Mar 27, 2010 | 02:21 PM
propane one's Avatar
propane one
modified b code ?
I am doing the v code front spring mod soon, why not just do the b code superduty rear spring without modifying the spring pack?
Old Mar 27, 2010 | 02:25 PM
Stewart_H's Avatar
Stewart_H
Lots of us do exactly that, put the B's on without modding them.
Years back, when I did the spring upgrade, I didn't mod my B's.
Stewart
Old Mar 27, 2010 | 03:55 PM
housedad's Avatar
housedad
Back then, the reason that I figured out how to modify my B's was that I had Firestone airbags and did not want to have to use a taller riser block from the F350's to get the rear height up to match the fron V codes. Using a 350 block would have meant that my Firestone bags and mount would not work.
The lift was cheap (as in no cost) and it lifted it extremely well. It is not for everyone, and it is just an alternative to get a reasonable lift.
Benefits for me was it lifted the rear 2.9 inches and increased the spring rate. I really wanted the increased rate for towing trailers, and I had almost no budget left for parts.
Lately, I have added a vvery heavy front bumper, and my front end is down enough for the heght difference front to rear to be very noticable. So I have a 2.5" add on spring pack from Summit to put on in the front. This will level the whole thing out with a total of 4.25" of front lift and 2.9" of rear lift. (the rear is between 1 and 1.5 inches taller from the factory to start with)
But, like I said, everyone has different needs, desires, and wallets. Just look around hard and pick the spring option(s) that sound best for you.
Old Mar 27, 2010 | 07:12 PM
Stewart_H's Avatar
Stewart_H
That there is EXCELLENT advice.
If I had to do it all over again, I'd go with W codes up front and either B codes on the rear and RAS, modded B's and RAS, or possibly C codes and RAS.
If I did the C's on the rear, depending on how high it lifted the rear (along with the RAS), I'd probably want to add a spring pack to the W's up front.
Stewart
Old Mar 27, 2010 | 07:29 PM
billman13's Avatar
billman13
I thought that it was necessary to use the 3.5" block instead of the stock ex block to get the proper pinion angle. Does adding the two leafs from the ex give the b codes the proper rise? I am currently waiting on the blocks to install my b codes. I only want to do this once so if someone could clarify........
Old Mar 27, 2010 | 07:41 PM
Stewart_H's Avatar
Stewart_H
I wouldn't say necessary, but I would say prudent, or recommended.
There have been posts where guys have done the B's on the rear, kept the stock flat block, and have driveline vibrations that were solved by swapping in the tapered blocks.
There are also guys who have been ok with using the stock block.
Also, using the bigger tapered block raises the rear enough so that the front isn't higher.
Stewart
Old Mar 27, 2010 | 08:47 PM
housedad's Avatar
housedad
For all you ever wanted to know about driveshafts, U joints, angles, and vibration, I found the web site below to be excellent. A bit of a read, but when you get done, ou can determine through proper measuring, whether or not your finished setup has the right angles or not. The guy who did the writeup did a great job.
Pirate4x4.Com - Extreme Four Wheel Drive
Old Mar 27, 2010 | 10:04 PM
njneer1's Avatar
njneer1
Saw someone talking "P" codes for the rear that utilized the stock block.....ever heard of them ??
Old Mar 27, 2010 | 10:12 PM
DaveandJennyP's Avatar
DaveandJennyP
I have the modified B's and like them alot. I was going to use the B's as they were but I got impatient waiting on the taller blocks that I had to order. By going the modified route I was able to keep the shorter blocks (which should reduce the tendancy for axle wrap), save money (no bigger blocks to buy), get it done right away, get the correct amount of lift and increase the capacity.
I tow a 6500lb. Travel Trailer with 900lbs tongue weight and they work really well. Also, I have not had any driveline vibration issues with this setup.
The process of modifying them was not difficult. A couple good sized c-clamps and longer center bolts was pretty much all you need to do it.
Old Apr 4, 2010 | 07:06 PM
billman13's Avatar
billman13
Things went well with the v and modded b swap. only problem is after pulling home my new TT I have a leak in the rear pinion seal. Is this a coincidence or related to the spring swap or TT? Either way I could use some advice on pinion seal stuff.
RobertH
Jul 12, 2015 04:16 PM
lfthrdr
Feb 6, 2015 04:40 PM
lawlfailmail
Nov 18, 2014 05:05 PM
Magnolia Tom
Jan 30, 2014 10:21 AM
