90/7.3 won't start
Old Feb 24, 2011 | 07:45 PM
george ulrich's Avatar
george ulrich
90/7.3 won't start
Quick question, 1990 E350 box van that has sat for about a year. The motor cranks fine, and has fuel pressure, I guess the glow plugs would be the place to start. Any input appreciated.
thanx
Old Feb 24, 2011 | 08:49 PM
oreocreaming's Avatar
oreocreaming
ya, glow plugs for sure. 90 so its got the black/brown box with a relay on it. test it and see if it clicks and stays on for a while (10+ seconds optimal) then you should be good. if you wanna see if it will run before you spend your time, you can do a quick quick spray of starting fluid. it will fire without glow plugs with that. if it runs then your good and know its a glow plug issue. lucky *******, you can just lift off the cover and easily get to the controller while inside the cab.
Old Feb 24, 2011 | 09:29 PM
Brick Nose Red's Avatar
Brick Nose Red
Hey oreo, not to sidetrack from the OP, but what is your amsoil bypass system??
Old Feb 24, 2011 | 10:28 PM
oreocreaming
it's a 2 filter oil bypass system. Click on my name, then profile. Click stats then find threads started by oreocreaming. I did a write up on it.
mybitta1
Mar 31, 2013 05:25 PM
jsa3107
6.7L Power Stroke Diesel
Aug 8, 2012 09:06 PM
ahgoo
Oct 10, 2011 09:29 AM
Saxon
Jul 19, 2004 04:18 PM
deadeye
13
Jul 27, 2002 08:45 PM
