Sponsored by: Real Truck
fuel problems powerstroke
Old Feb 23, 2011 | 02:25 PM
prox429-powerstroke's Avatar
prox429-powerstroke
Just happened the other day driving down the road an it just went dead no sputter or chuging just died. A buddy has a 2000 and his fuel bowl heater went out and tooke the 30 amp fuse . So i check that it sounds like pump is working and when i pulled the filter off the top by water seperator it had press. and there is fuel in the bowl. I have 911 diesel service in the tank an in the filter. when i try to start it turn s over fine but i noticed that there is no smoke or even smell like normial at the tail pipe. any ideas. I am open for any an all ideas. Thanks for your time.
Old Feb 23, 2011 | 03:52 PM
Pocket's Avatar
Pocket
Your profile says your truck is a 99.
Check to see if your tach moves while cranking. If the tach doesn't move while cranking, it's a failed CPS. The CPS is one of the most common causes for a truck to suddenly and without warning die, and not start again.
Old Feb 23, 2011 | 04:21 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Pocket (likely) has you covered. If you need a new one, first I would check and see if you've had the recall done for the CPS. The recall gives you a new "grey" CPS as a 'fix'.... if you can get that freebie, get it. If not.. you'll have to buy one. Even if you get the free one, I'd still buy a "black" CPS - your truck will thank you for it.
Riffraff Diesel: Sensors
Replacement O-rings for Ford Diesel Engines
You should bookmark both those websites - you'll save a bunch by buying through them. There is also www.partsguyed.com for other OEM parts - all 3 will take care of you, as will any of the other sponsors of this site. Good luck.
Old Feb 23, 2011 | 04:24 PM
prox429-powerstroke
feul isues???
Ya thanks tach works and oil press. gauge works .I am tryn to think of anything else but i am get at the end of easy ideas. thanks for the input. steve.
Old Feb 23, 2011 | 06:32 PM
WABO's Avatar
WABO
what is the CPS
Old Feb 23, 2011 | 06:58 PM
sezwho's Avatar
sezwho
engine dies
My truck died in traffic a couple of weeks ago,killed my batteries trying to start to no avail.Got towed and turns out to be clogged fuel filters.Seems to be the answer so far. Hope this helps.
Old Feb 23, 2011 | 07:07 PM
F350-6's Avatar
F350-6
Did you check your fuses? The reason your buddies truck died when the fuel bowl heater shorted out is because that fuse also powers the truck computer. No computer = not running.
If it died suddenly, also check to see if the tin nut came off the back of the IPR.
Old Feb 24, 2011 | 04:54 PM
prox429-powerstroke
What is the tin nut on irp??
Old Feb 24, 2011 | 05:10 PM
Fishin76's Avatar
Fishin76
The tin nut holds the IPR together, but it is rather flimsy. It is a rare occurance that that would happen, but possible. The IPR is a valve that lets oil into the heads or lets it drain back to the pan. It also varies the pressure that the injectors see from the HPOP by regulating the drain back rate. An intact IPR will not cause a sudden shutoff, but can contribute to hard starting for sure.
Sounds like CPS to me also.
Old Feb 24, 2011 | 05:48 PM
prox429-powerstroke
Just tryed new camshaft position sensor and still nothing? This stuff never happen when its a sunny warm day.lol Guess i ll have to pick up a scanner an see what it tells me . Hopefully it tells me something , Thanks for everyones help an ideas. Steve
finerant
Apr 16, 2015 12:17 PM
dzhony
13
Jul 17, 2013 01:45 PM
david4200
May 13, 2010 06:33 PM
BENG0924
Jan 7, 2009 09:40 AM
BowDown
13
Mar 7, 2006 10:50 AM
