Getting fan off 302?
Pulley fits onto water pump shaft, tolerance very close and after setting for year(s) at a time rust and grime can make removing very difficult. Suggest taking a rubber mallet, or something simular, and gently tap on the pulley while turning, don't want to force and worp the pulley. I have an extention for the fan thus unable to see the water pump shaft, if yours is visible suggest applying some WD-40 or something simular.
GMB North America 125-1420P - GMB High Performance Water Pumps - Overview - SummitRacing.com
March Performance 1618 - March Performance Aluminum V-Belt Water Pump Pulleys - Overview - SummitRacing.com
The 4 fan bolts pass thru the spacer and pulley and bolt to the waterpump.
Wiggle the fan back/forth, that should loosen it enough to remove it.
