6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
turb noise?
Old Feb 23, 2011 | 06:49 AM
Gwilkrrs's Avatar
Gwilkrrs
turb noise?
i noticed the truck running louder so i looked under the hood. the air filter minder is half yellow so i ordered the filter from the dealer- will be here this afternoon. i noticed the noise (air)is coming from under the silver metal cover over the turbo's. i havnt noticed the truck running bad, just loud.......... what could this be?
Old Feb 23, 2011 | 07:49 PM
stewy83's Avatar
stewy83
remove the 8mm bolts then remove and inspect the bottom side of the shield for black soot. most likely leaking from graphite sealing ring where the turbos meet together. the "wire mesh" looking ring is not an actual gasket.
Old Feb 24, 2011 | 06:50 AM
Gwilkrrs's Avatar
Gwilkrrs
THANKS. if it is sooty how large a repair is this?
Old Feb 24, 2011 | 07:39 AM
Gwilkrrs's Avatar
Gwilkrrs
ok- went to remove shield- all bolts removed THEN the one in the back under the cowl...... not even 1/4 turn and the head popeed right off. damn. ayway there is a metal pipe running over the shield so it wont come off to see under it. there is linkeage next to the shield that may be for the turbo---- with truck running i applied preasure to this and the noise changed. i am sure the noise is turbo related ....... is this a large repair?
Old Feb 24, 2011 | 08:14 AM
senix's Avatar
senix
Might be a cab off procedure depending on the tech that does the work.
doesn't have to be.
Warranty related though.
Old Feb 24, 2011 | 08:26 AM
Gwilkrrs's Avatar
Gwilkrrs
thankfully extended warrenty here- early 08 with 51k.
should i have it looked at asap or doesnt it matter?
Old Feb 24, 2011 | 09:24 AM
senix's Avatar
senix
don't think you have hurt a thing.
Old Feb 26, 2011 | 11:48 AM
Gwilkrrs's Avatar
Gwilkrrs
i took the cover off... no soot anywhere. could this be exhaust related?
Old Feb 26, 2011 | 12:59 PM
stewy83's Avatar
stewy83
there are 2 pipes that come up from the manifolds to turbo that could leak at connections, also one coming from off the right side up-pipe is another pipe with the doc (Diesel oxidation catalyst) that connects to the horizontal egr cooler on left side. not to mention the down pipe from turbo to the dpf, muffler, and tailpipe. turbo/exhaust leaks are not much fun to find or fix on 6.4l. hope this helps.
eta: the most common is a crack where the flex joint is on right manifold to turbo pipe. hard to find the soot because its usually the side facing the back of engine.
Old Feb 26, 2011 | 05:22 PM
senix's Avatar
senix
maybe you can run it up on some ramps, get under there with the motor running and maybe hear where it is coming from.
Shine a light up there and maybe it is cool enough outside to see the hot gases escaping.
I dont know if that would even work.
Old Mar 1, 2011 | 10:51 AM
Gwilkrrs's Avatar
Gwilkrrs
we are pretty sure it is exhaust related but cant find hard evidencew to support this. if so is this type of issue covered under esp extended warrenty?
Old Mar 22, 2011 | 07:02 PM
Rescue401's Avatar
Rescue401
I am having the same problem, on a whim I sprayed soapy water all over the turbo and found it to be leaking where the rod connects into the high pressure turbo. I dropped it off at the dealership a few hours ago and they told me the warranty is 5 years 100k so that was good news to me.
fordman19762003
6.2L V8
Jun 27, 2017 02:29 PM
cookingguy
Jul 15, 2016 03:14 PM
Bryan Hagan
Feb 27, 2016 01:38 AM
jjlrrw
Nov 8, 2015 10:52 PM
pat420swed
21
Jul 26, 2014 01:30 PM
