Undercoat...yes or no?
Old Feb 22, 2011 | 07:54 PM
PITS's Avatar
PITS
Just curious if you had your truck undercoated. I know when I pick mine up at the dealer, they, like every other dealer, will route me through the aftermarket parasite's office in the hopes I will overpay for some other option they didn't offer originally. I have purchased almost everything extra I want already and saved a buttload of money by shopping and buying online but undercoating is one I am not too sure on. Sounds like a good idea and the dealer price doesn't sound too out of line...around $250 but I haven't really shopped around yet.
My question is: Is it worth it? Will it really cut down the road noise? I live in Missouri where they do use a lot of chemicals on the roads in the winter. Does it protect enough against that to warrant the cost?
How many of you opted for it from the dealer?
Old Feb 22, 2011 | 08:16 PM
rickatic's Avatar
rickatic
I live in Michigan, bought the truck in Nebraska and got the UC sales pitch...I declined...good description with the "aftermarket parasites"...
Old Feb 22, 2011 | 08:32 PM
gearloose1's Avatar
gearloose1
If undercoating is applied at the factory or on new metal... it does do little harm.
The problem is, as an aftermarket coat, contaminants have already gotten on the surface, and if you put undercoat, it traps moisture and contaminants right up against the metal, starting a corrosion pocket between the stuff and the metal.
Not a good idea in general.
If you really worry about rust... I have some neat solutions.
Old Feb 22, 2011 | 09:00 PM
Marauder92V's Avatar
Marauder92V
I was always an "undercoating" guy using typically Ziebart. I found out two things, first that the new trucks are treated for corrosion protection at the factory. They are less likely to rust than older cars/trucks that are not treated. Second, I would always find rust under my "undercoated" vehicle and never really understood why. Some was related to what Gearloose said but also found out that undercoating can actually trap moisture in seams causing them to rust. By the time you get to your yearly "re-treat", the damage has already started.
Some guys are Line-xing their undersides but I opted for another option. I had been using Fluid Film on my snow plow equipment for years. I never had a rust issue with any of the equipment. I decided on this truck to use it. I bought a cheap industrial sprayer and a gallon of Fluid Film. It took me about an hour and about half of the can. It has been on since early December and I went to check on it this past weekend. No rust! And the protection seems to be holding up against the northeast salt and snow.
Old Feb 22, 2011 | 09:03 PM
gearloose1's Avatar
gearloose1
My solution is to use a cold-galvanizing coating....
It will stop rust dead in its tracks for several years at a time... then it can be renewed.
80% zinc by weight.
Old Feb 22, 2011 | 09:14 PM
Mark250's Avatar
Mark250
I bought an old truck that had more damage from undercoating than it would have had with none. As others have stated, it was applied too thick, then it trapped moisture & rusted the metal out.
Now I have undercoated one of my trucks in the past when it was brand new. Removed the inner fenders & applied a light, even coat of rubberized undercoating that you can buy in the cans to the sheet metal underneath. That worked great, and the truck has no rust (a 1991 that my son now has).
I have also been herded through the parasites at the dealer that try to make you feel like a loser if you don't buy their product "What, you don't want to protect your new truck???" No sale here.
Old Feb 22, 2011 | 09:53 PM
Sgt93's Avatar
Sgt93
The Fluid Film seems to be working pretty good so far
Old Feb 22, 2011 | 11:52 PM
PITS's Avatar
PITS
The Fluid Film looks good in the videos. How often realistically would it have to be re-applied in an undercoat situation? And where is the best place to buy?
Old Feb 23, 2011 | 05:35 AM
Jasper 1's Avatar
Jasper 1
Undercoating
I have used Krown on all of my trucks since starting a program with my Township fleet of trucks, I find it stops rust, makes repairs easier and stops wiring shorts. I do the fleet every fall before winter along with my truck and am very satisfied.
Old Feb 23, 2011 | 10:06 AM
Noah2010's Avatar
Noah2010
Got it done at the dealer. I do not know if it helps with road noise as I was never was in the truck with out it. Seems to be split as to whether it is worth it or not. I decided to do it because it made me feel better.
Old Feb 23, 2011 | 10:24 AM
Marauder92V
What I have found that on items that tend to rust and they are out of the road spray path, once a year will work fine. Areas that are in the road spray path will probably require two treatments a year (after 3.5 months these still look fine). I also painted on with a brush areas that could not be sprayed easily (wheel knuckles, etc.). The good news is that it will stop rust if you miss an area and apply it later. It is also not chemical based and the environmental impact is minimal.
John Deere dealers carry it but you can find better online deals using their vendor list: Fluid Film® | Corrosion Preventative, Lubricant and Rust Inhibitor or just by Googling it. I have a local snow plow shop that stocks it.
Old Feb 26, 2011 | 10:17 AM
martin123456789's Avatar
martin123456789
That undercoating/gunk they spray will trap water/salt as soon as it cracks.
I just took all the undercoating off on mine, everywhere there was a chip/crack in the undercoating, there was rust.
I have used Gearloose's idea and applied zinc rich paint everywhere + paint + professionally rust proofed + oil.
So far so good this winter, not a trace of rust on the frame yet..
(To be confirmed this summer)
Old Jan 25, 2014 | 04:33 PM
Davie J.'s Avatar
Davie J.
I talked to a guy who used Rhino Liner in his fender wells and he swears by it. Does anyone out there have experience with that or other bed liners used as an undercoat? I'm considering using Eastwood undercoating on the frame and underside of my truck and I'm thinking the bedliner might be good for the fender wells. Please comment.
Old Jan 25, 2014 | 04:49 PM
SavageNFS's Avatar
SavageNFS
I use fluid film as well.
Old Jan 25, 2014 | 04:57 PM
senix's Avatar
senix
I under coating mine when I bought it. Drove it home and did it. I have always had good results with it myself.
Since it had not been driven but 7 summer miles when I bought it I went ahead.
Now that we have had several snow storms and my white truck is even whiter I think I made the right choice.
I also painted the entire underside components and things as well.
Then fluid film. We will see what it looks like in the spring.
