Burning smell?
Old Feb 22, 2011 | 07:20 PM
Molineguy's Avatar
Molineguy
Burning smell?
On my 92 F150 xlt, when I first start it, there is a burning smell. It doesnt smell like oil or gas, it smells electrical. It doesnt always do it, but I can't figure out where its coming from. Everything works and no blown fuses. I thought maybe it was the blower motor going bad, but it doesnt squeel and there is no smell after it is running a bit. The smell doesnt last long so I have not been able to find where its coming from and it doesnt do it every time. Anybody ever had this happen or have an idea what might be going on? Thanks for any help.
Old Feb 22, 2011 | 07:23 PM
octaneforce's Avatar
octaneforce
maybe a starter wire is getting hot and melting when you start it? just a shot in the dark
Old Feb 22, 2011 | 07:25 PM
Flareside13's Avatar
Flareside13
I would agree probably a starter wire shorting onto the frame could even be a ground doing the same. A thin cover on the wire could be causing the smell when it shorts threw it.
Old Feb 22, 2011 | 07:39 PM
rikard's Avatar
rikard
Check the blower resistor block located in the housing under the hood. Could also be a heater core about to fail.
regards
rikard
Old Feb 22, 2011 | 10:43 PM
drjoe171's Avatar
drjoe171
Is it stronger INside the cab or under the hood?
Computers like to do that as the start to go bad.
My starter was intermittent but I only noticed it sparking when I had the hood open in the dark as my GF cranked it with the key.
Old Feb 22, 2011 | 11:04 PM
Bovaloe's Avatar
Bovaloe
regards
rikard
Not trying to thread jack but I get a burning smell when I turn on the heat in my 88, only blows a little warmer air though. Could the blower resister be the culprit? How would a heater core getting ready to blow cause this?
Old Feb 23, 2011 | 07:18 AM
Molineguy's Avatar
Molineguy
Moline_guy
Thanks for the information, it seems like its on the inside. I will let someone start it and look around under the hood, but I havent hoticed any melted wires. I will have to check around a bit more and see whats going on for sure. Thanks for the ideas.
96f150
1997 - 2003 F150
Apr 10, 2015 08:42 PM
stonefinder1
Oct 16, 2014 01:28 PM
Jolly Roger Joe
30
Jan 12, 2013 12:16 PM
eman588G
Oct 31, 2009 06:26 PM
superpelly
May 3, 2007 06:53 PM
