wiring harnesses??
Old Feb 22, 2011 | 05:01 PM
FordmanShane's Avatar
FordmanShane
wiring harnesses??
I'm thinking about getting a new wiring harness now since i can't seem to get my turn signal working right ..that and there are just so many wires chopped, i have looked on here and around, i found EZ wire not to bad for $175, have you replaced or going to replace your harness? send me a bookmark.. thanks
Old Feb 22, 2011 | 06:31 PM
BDawg171's Avatar
BDawg171
Are you looking for a complete truck harness or just something for the turn signals area? At the price you are indicating I assume you are just looking at turn signals stuff ???
Old Feb 22, 2011 | 07:17 PM
bucks77ford's Avatar
bucks77ford
I replaced my entire harness from Centech. It was pricey, but was made with all FORD connectors. I had to use very little from my old harness.
Old Feb 22, 2011 | 09:30 PM
FordmanShane
good news
I was looking at those as-well on bronco gy for $65 oem $45 am. I just barely tracked the issue down to the hazard light switch, it doesn't full disconnect, i have to push the switch in and everything works!! ill start looking in pick n pull for a clean harness. eventually i will have to replace the entire harness..
im looking for the entire harness..
right on i don't mind spending an extra dollar for quality..
Old Feb 22, 2011 | 10:52 PM
whitleycj's Avatar
whitleycj
I installed the ez wiring harness for my pickup a few weeks ago. Its all gm connections but it wasn't a problem to switch a few connectors. Works beautifully and I have had no problems with it whatsoever. Very glad I did it. Will make tracking any future wiring problems simple, although I don't think I will have any for a long time
