76 F-100 backfire problems?
Old Feb 22, 2011 | 07:17 PM
lawdogg_78's Avatar
lawdogg_78
Ok...So, I have a 1976 Ford f-100 with a 360. (thought it was a 390, but it's a 360) When I start it up cold, it backfires through the carb. I thought it was a timing issue, so I had a mechanic check the timing while it was in the shop getting new exhaust. As I thought, the timing was set back to 3 and is supposed to be between 6 & 8. When he put it up to 8, it idled fine but would backfire really bad through the carb. He said he "thinks" I might have a bad timing chain. He is going to leave it set at 3 so it will run ok. My question is this...How can I be sure it's the timing chain and not something else?...stuck valve, bad carb, worn lobe on the cam, plugs not gapped right, firing order off, distributor off one notch? Anything? Any ideas? Anyone run into a problem like this? Any help would be greatly appreciated. Thanks
Old Feb 22, 2011 | 10:47 PM
fmc400's Avatar
fmc400
MSEE
Backfiring on a cold start often means the choke is not closed at startup. Check that out.
Old Feb 23, 2011 | 12:51 AM
ford1977owner's Avatar
ford1977owner
FMC is right sounds like ur choke isnt closed
Kyre Searcher
17
Jan 29, 2015 05:10 PM
Thipdar
Apr 15, 2014 12:26 AM
Sam
May 15, 2011 11:24 AM
DictatorDanny
Oct 18, 2006 06:04 PM
GDANET
Aug 21, 2004 10:31 AM
