Sponsored by: Real Truck
Door Chime sending a message?
Old Feb 21, 2011 | 07:12 PM
Robert_Mays's Avatar
Robert_Mays
My door chime just started beeping at me today in code I believe. After I start the truck it will beep 5 times, wait a sec, beep 5 times again for a total of 5 rounds of 5 beeps. What is this thing trying to tell me. Oh, and its a '99 SuperDuty XLT 7.3. Thanks guys
Old Feb 21, 2011 | 07:30 PM
dchamberlain's Avatar
dchamberlain
Does your SRS (air bags) warning light come on when you start the truck? I have heard, but never witnessed, that if the SRS warning light is burnt out the instrument cluster will chime to warn you. They figure SRS is important enough that you need to know if the warning light is not working.
Old Feb 21, 2011 | 07:33 PM
projectSHO89's Avatar
projectSHO89
It's telling you to see your owner's manual (the answer is inside it).
Old Feb 21, 2011 | 08:40 PM
Robert_Mays
Hmmm.....airbag light was on and i took the cluster out today to replace some illumination bulbs and noticed the airbag light was off but the bell was ringing. Interesting.
Old Feb 21, 2011 | 08:42 PM
dchamberlain
The air bag light should come on when you first turn the key to run, along with all the other lights so you can see they are working. If it does not, it's not working. This light is tested, by either the cluster or the ABS module, not sure which. If it isn't working, the dinger warns you.
Old Feb 22, 2011 | 04:16 AM
scraprat's Avatar
scraprat
Top Answer: 5
It has to do with the light that's out. You'll also notice on long drives that it will keep repeating every so often.
shadyEats
1983 - 2012 Ranger & B-Series
13
Jun 15, 2015 02:00 PM
mainecorrado
Jul 17, 2008 12:02 PM
zambouicc
Aug 4, 2005 08:44 AM
Bliath
1997 - 2003 F150
Jul 22, 2005 11:37 AM
John7894
Jan 4, 2005 01:33 PM
