Engine code scanner - check engine light not on
Old Feb 21, 2011 | 05:58 PM
4Ranger4's Avatar
4Ranger4
This is kind of a random question me and my friend were discussing. We were wondering if something were awry with the engine but the check engine light wasn't on if a scanner would still let you know. He is getting a feeling something is wrong with his truck but his check engine light hasn't illuminated.
Old Feb 21, 2011 | 09:05 PM
pawpaw's Avatar
pawpaw
Well the answer is maybe!!!!
"Pending" codes can be stored & the CEL not be lit.
Other things can be wrong, but if the computer isn't monitoring them, a CEL won't be lit, nor a pending code stored, Unless the problem adversley affects something that IS being monitored by the computer.
SO, if he has a "scantool", that'll monitor live PID feeds to the computer, he might be able to get an idea of whats going on by reviewing the PID's the scantool can monitor, to see if any parameters look abnormal.
Old Feb 22, 2011 | 05:32 AM
powersmoked's Avatar
powersmoked
+1....I have solved a few issue by "catching" a pending code...........also make sure the CEL comes on when you first turn the key to ON/RUN
Also if something with your Truck is "wrong" the first thing you should do is bring all the maintenance up to Par.....a lot of times that solves the issue...
Old Feb 22, 2011 | 09:37 AM
bulldogchief's Avatar
bulldogchief
+1 on both of these...I've seen this before as well, and doing any past due maintenance is a great idea...
herojeep
S. California Chapter
Nov 4, 2011 02:24 PM
78 PEB
Feb 10, 2011 01:35 AM
lennb01
17
Nov 10, 2009 05:58 PM
MONAVIERONJON
Sep 9, 2009 07:06 PM
jersan
Mar 30, 2006 11:39 PM
