351w build questions
I found a 351w in town that's taken apart for a rebuild. It's from a '78 Ford Elite.
I've worked on engines before, particularly the 302, but I've yet to fully build one up. It doesn't strike me as something that I'll get in over my head with but it does seem like one of those things where it would be wise to ask a few questions first so I don't end up doing something that causes a problem down the line.
I would like to get some decent power out of it, around 300hp, but it's also meant for daily driving so decent gas mileage as well. If there is a time to build it the way you want, its definitely when it's in pieces.
This isn't a dream build, just a practical one, I can't afford $2000 heads on it right now for example. So what would be the musts to swap out? Cam I'm sure, but what to go with? It's all stuff I know about but having never actually built an engine from the ground up I can't help but ask for opinions.
Things to look out for or be cautious of?
Thanks
I'm use to the 302 and from what I've seen the 351w is pretty close, so that makes a plus for it... not to mention it may find it's way under my '67 Mustang which is set up with a 302 currently.
It looks like a pretty decent deal, the engine I'm looking at has been taken apart but all there. If its just in need to be reassembled and not in need of a full rebuild kit, it could be a great deal for me. It's about time I learned how to rebuild an engine anyways.
The 351w seems to be a pretty ideal engine for me, it's something that I can use in multiple projects and interchange parts (when you have 4 small block Fords, it's nice to interchange things if you need). I may keep the 272 and build it up, but in truth the truck is a daily driver, and having to replace something on the spot is easier with a 351w than a Y-block.
The Gt40 heads seems to be a common mod, if I can find a cheap set and maybe an intake, that might be all I need. I guess the only thing left to mildly do this would be a new cam, but it might not even be necessary for what I'm using it for. Just want to build it strong and build it right, would hate to go through all the work then have someone ask, "So why didn't you put this in there while you where at it and have it be much better?" lol
To get 300 hp you will need to change the heads, camshaft, intake manifold and carburetor, for starters.
It might be wiser to search out a 1994 and up 351, as it has a roller camshaft. Nowadays there is some concern about excessive wear with flat tappet camshafts because modern oils do not contain so much of the additives that protect the camshaft lobe/lifter base contact surfaces.
Even with the 1994-up engine you will most likely be replacing those same items as listed earlier, to achieve 300hp.
Alright, like I said, I'm new at the whole rebuilding thing and don't know exactly whats good and what needs to be replaced. What all do I have to replace on it when putting it back together, I mean how do I know if a part has gone bad? I see rebuild kits that have pistons and everything else, I'm not looking to build a monster, it's my first engine build, I'm just giving it a go and want to come out with something decent. Maybe down the line when I am more experienced with it all I might have some more fun and put some more money down into it, but right now I just want something that will make it so I can drive my truck reliably (the 272 is sorta reliable, my ability to change gears with that transmission is not, lol)
The guy is cleaning out his garage, the 351w is in pieces but all there minus the carb, valve covers and oil pan. He also has a C4 (might be a FMX) that comes with it that he said shifted well. Course thats here-say but he only wants about $125 for everything and said he was willing to negotiant because he just wanted it out of his garage, so I might be able to get it for like $50. Seems like a fair place to learn how to build an engine.
What I am most weary of is the nickels and dimes. If I can re-use a part, I'd like to. I've been a professional blacksmith for many years and use to do machine work, I've worked on cars for many years just never actually put together an engine from the block up. Are there certain things that must be replaced other than seals? How can I tell if it needs this or that, such as honing the cylinders?
I'm not looking for a money pit, frankly I'm just looking for a good engine for my truck and to learn the process of building engines, there is a really good chance I will go back and re-do all of this in a few years with sparkly chrome and forged this and that, but right now I'm more curious of what it NEEDS, and how to tell if it's a need or a "it be nice". My project funds are pretty limited, but this could be something that makes my truck a whole lot more daily drivable.
I started with a stock bottom end, new rings, bearings etc.
A new cam and lifters is a "must" IMO. I went with comp cams XE262H and matching lifters.
For intake I chose a Weiand Stealth, but any dual plane 4bbl should be fine.
You'll definitely want different heads too. I couldn't find a good set of GT40's so I went with E7's with a bit of porting.
Any carb around 600cfm should work fine. I went with a used Holley 600cfm vac. secondaries and rebuilt it myself.
My engine should be around 300hp and 400ft/lbs. It cost me about $800 and many hours of enjoyment building it!
Crap.
If you're interested I've got a new Comp XE250 cam and timing set for a 351W gathering dust that I'd part with for cheap.
Get a RV/Truck cam if you want good fuel economy. Later when you have the cash you can get a set of GT40 heads, headers, 1.7 rockers, and still use any intake you choose to use now.
I had a 1993 Cobra Mustang. Using a stock short block including the cam but with a larger Mass Air meter, ported upper & lower Cobra FI intake and long tube headers I pulled 270 HP at the wheels on the dyno. In your case add 49 cubic inches and you are looking at 300 HP! The only difference would be that I had a roller cam and you would have a flat tappet one.
Thanks for the help guys. I think I'll have to wait on doing an engine build for a while, simply can't afford all the parts I'll need. The 272 in my truck only has about 25,000 miles on it (she was garaged for 50 years too, worked at a Gold mine, found silver nuggets in the glove box, ha) and I think it could be a decent engine for me till I need more power. The 351w was just something that came up and if I could have just put it back together and paid $100 for it an a c4, it seemed like a good idea, lol. But I have a feeling it would be one of those never ending journeys for a while and one more thing to move...
If you could find an early 90's motor with AOD attached, that might be your best bet.
Look for a good used set of GT40's and just bolt them on.
