Sponsored by: Real Truck
electrical problem
Old Feb 21, 2011 | 02:35 PM
Edkajo's Avatar
Edkajo
electrical problem
03 f350 lariat 7.3L
Just had the power windows, radio, visor mirror lights fail to work today.
(appears to be all the delay items)
Checked fuses and delay accessory relay, all are fine.
What would be the next most common culprit that might cause this?
On a side note about a month ago I experienced 2 or 3 occasions when the key failed to turn right away, as if the wheel was turned with some pressure on it ( binding the key )but that wasn't the case. After a few taps on the column it turned and everything has worked fine until today. I'm leaning towards a problem with the ignition switch but ..........not sure if that should be the next easiest thing to check or not.
Any suggestions are appreciated, Thanks
Old Feb 22, 2011 | 08:56 AM
Edkajo's Avatar
Edkajo
Very slow and not very good at it but did some more research and found a 2007 post from beerstalker on this site. Ended up being #41 10amp (instrument panel) fuse even though the panel was working fine.........go figure.
Also came across intructions on an easy fix for the overhead temp/compass unit that's been out for awhile as well.
Very informative site....thanks!
srteach
6.4L Power Stroke Diesel
Oct 17, 2012 07:47 PM
shad
Jul 17, 2012 06:45 PM
Unwound
Jan 28, 2005 01:55 PM
tomf250
Jan 9, 2005 09:33 PM
