6.0 exhaust manifold gaskets
If I remove the plastic inner fender liners(hope thats what their called) would it make it alot easier to install the new exhaust manifold gaskets? Or would I just be adding to the amount of work to be done? I was going to do it today but its still a little chilly here to do it outside, and the clearance for the top side bolts is quite limited.
Thanks in advance.
P.S. Anybody know the correct torque for the bolts, I'll be adding some antiseize as well.
Thanks in advance.
Just saying it is pretty unusual for these to leak. If they are truly leaking then they are warped. I would pull them off and have them surfaced at a machine shop instead of putting gaskets on.
As far as pulling them goes you can do it without pulling the fenderwell but it is a little harder.
Better listen to him......
What he said. Start it cold with the hood open and crawl underneath and look up with a flashlight. I vote for up-pipes. Manifolds rarely leak.
Ford sells manifold gaskets, fyi.
I just replaced my manifolds a few weeks ago due to warping, and I installed the Ford gaskets along with the new manifolds. In my case, the soot marks around the exhaust port at each cylinder made the diagnosis pretty obvious.
Warped exhaust manifolds is not totally unusual, but it is good to be sure before fixing/replacing them.
I just replaced my manifolds a few weeks ago due to warping, and I installed the Ford gaskets along with the new ones. In my case, the soot marks around the exhaust port at each cylinder made the diagnosis pretty obvious.
hotrod351
09-07-2018 05:10 PM
danohall
10-20-2007 03:35 PM
