Problem with moonroof
Old Feb 21, 2011 | 11:20 AM
nut1605's Avatar
nut1605
I tried posting this in the Super Duty forum but didn't get any bites so I thought I would try it here.
2011 F-350 Crew Cab with the moonroof. Today when I closed it, there was a pretty solid "pop" from the right hand side and the glass moved a little odd. I opened it and closed it again and the same thing. At first I was thinking the glass was catching on the sheet metal as the back of the moon roof was lifting up to create the seal. However I watched it close as I was outside the truck looking at the roof, and that definitely wasn't the case, plenty of clearance. I have pretty much decided it is something that is possibly binding in the mechanism itself, but I can't visually see what it could be. Anybody had this happen and knowhow to fix it? It's about an hour and a half round trip to my dealer, so I don't want to waste the time if it's an easy fix.
Old Feb 21, 2011 | 06:36 PM
11superduty's Avatar
11superduty
Ice? or it maybe it's out of adjustment in this case the headliner will have to be R/I to aline the moon roof assemble, this takes some time
Old Feb 21, 2011 | 07:06 PM
brmccolley's Avatar
brmccolley
Take it in for diagnosis
At the very least, have a service tech look it over and note the issue. Perhaps a bit of lube will fix it. Otherwise, why wait for it to fail at an inconvenient time.
Old Feb 21, 2011 | 08:33 PM
Biggziff's Avatar
Biggziff
I don't think he was waiting for it to fail based on his comments...
Originally Posted by nut1605
"Anybody had this happen and know how to fix it? It's about an hour and a half round trip to my dealer, so I don't want to waste the time if it's an easy fix."
Old Feb 22, 2011 | 04:26 PM
nut1605's Avatar
nut1605
No ice here, it's been at or near 70 for quite a few days (finally, no more snow and ice!!).
I was tinkering around with it again today trying to figure it out. The first couple times I open and closed, it went very smoothly with no "pop". After that, each time I did it, it got progressively worse. So it's almost like something is loose allowing it to get more and more out of alignment each time I open. I guess I will just not use it for now and take it in next time I am near my dealer!
Old Feb 22, 2011 | 06:35 PM
11superduty
Yeah sounds like a loose or missing bolt or a spotweld broke, your dealer is your best bet Good Luck!
jeinan3
Dec 15, 2015 10:01 AM
nut1605
6.7L Power Stroke Diesel
May 25, 2011 05:28 PM
lakedweller
All Things Towing
May 19, 2011 10:47 PM
Jeffery the first
Mar 8, 2011 05:30 AM
jxg1205
Aug 26, 2008 02:01 PM
