glowplug relay
Old Mar 12, 2003 | 05:21 PM
A3M9B's Avatar
A3M9B
glowplug relay
bought a new relay that has 4 posts, my 97 350's relay has 3 posts. continue looking for new relay....?
Old Mar 12, 2003 | 09:59 PM
psd tech's Avatar
psd tech
glowplug relay
Typically the G/P relay has 4 posts. Two large posts ( bat pwr input, G/P pwr output) and two smaller posts ( pwr and ground). A relay is uses a small current to controll a larger current.
Old Mar 13, 2003 | 10:33 AM
A3M9B's Avatar
A3M9B
glowplug relay
thanks for the reply. napa and another parts store both come up with one with 4 posts. dealers has 4 posts ($98, by the way). mine has 3 posts...really. am i missing something here?
Old Mar 13, 2003 | 12:32 PM
psd tech's Avatar
psd tech
glowplug relay
Where is the relay at? They may be using the case as the ground, although I have not seen this before.
Old Mar 13, 2003 | 03:29 PM
A3M9B's Avatar
A3M9B
glowplug relay
well, bare with me here. i figure it's that selenoid looking unit with the wires coming from the battery and leading to the valve cover. it's mounted to the inside of the passenger side fender close to the battery. it's mounted to metal. ...while we're at it.. after reading previous posts, i'm trying this before i look towards replacing the glowplugs. won't fire up in the cold, yet starts just fine when it's plugged in. ...?
Old Mar 13, 2003 | 07:10 PM
Quadzilla's Avatar
Quadzilla
glowplug relay
My truck is from the previous body style, but my glow plug relay is mounted directly above the passenger side valve cover, at the front. I, too, have a solenoid mounted on the side of the engine compartment, but I think that's the starter solenoid, or something similar.
What are your symptoms? Extended crank time, lot's of white smoke, but eventually starts? That's what mine was doing until I replaced the glow plug relay two weeks ago.
On my truck, the correct part was GP/109 from NAPA, but I'm not sure on your rig.
I hope this helps.
Old Mar 13, 2003 | 10:06 PM
psd tech's Avatar
psd tech
glowplug relay
Quadzilla is correct, you are looking for the relay on the front of the right valve cover. I was thinking that you had the wrong relay thats why I asked. Also, to test your glow plugs... Take a test light and hook the alligator clip to the positive battery lead and remove the connectors from the glow plugs and touce the tip of the test light to the end of the plug. The ones that don't light are bad. For the system to operate correctly you need to have all plugs working. Good Luck.
Old Mar 13, 2003 | 10:08 PM
psd tech's Avatar
psd tech
glowplug relay
I'm currently working on a 97 at the shop and its on the right valve cover as most/all.
Old Mar 16, 2003 | 10:17 AM
A3M9B's Avatar
A3M9B
glowplug relay
appreciate the info
Old Mar 20, 2003 | 06:41 AM
99sdpstd's Avatar
99sdpstd
glowplug relay
Hey psd tech,
Do you need the key on to check this??
Old Mar 20, 2003 | 08:39 PM
psd tech's Avatar
psd tech
glowplug relay
The engine and key should be off. Remove the glow plug connector and touch the post that the connector slides on to. Basically your checking continuity to ground, I assume that most of you don't have a ohmmeter. Power from the relay and a good ground @ the glow plug and a plug that is not open = heated combustion chambers.
Old Mar 20, 2003 | 09:57 PM
99sdpstd's Avatar
99sdpstd
glowplug relay
Thanks psd tech I will try that this weekend. If you would have said continuity check I would have gotten it. Glad I asked and you answered.
Thanks
Old Mar 21, 2003 | 08:00 PM
psd tech's Avatar
psd tech
glowplug relay
No problem, glad to help
Old Apr 10, 2003 | 11:04 PM
rts's Avatar
rts
glowplug relay
I would like to pick your brain for afew answers if possible about my 95 F350 5-speed 2-wheel drive truck.
I'm having a cold start problem and was thinking that it was the glow plugs. I went ahead and started to
take them out of the engine and checked them and the wiring circuit and checked out OK! That is when I
found that the relay wasn't working. The crappy book that I have which is a Chilton's said that the glow
plug system stays on from 2-10 seconds until the engine starts, and then cycles for up to 40-90 seconds
to clear the excess fuel. So I replaced the relay and and then the relay stayed on all the time, which
meant that the glow plugs were on all the time. So I unplugged the wire from the
relay and was trying to find out what times out these glow plugs!
I have been reading all these messages on this site, and it seems that the relay is the culprit.
But no one mentions about the timing of the glow plug system! I've worked on Mercedes for 20 years
and there are sensors that switch the glow plugs off after start-up. I see that some people put a
momentary switch on the dash, but I don't like rigging something without knowing that it is possible
to fix it right. Of course the repair books just suck when it comes to looking at illustrations. I you
have any idea of if there is something in the system that I can check or replace (timer,switch,relay,or
main computer) to get the system working right would be greatly appreciated.
dieselsubmariner
Nov 3, 2014 01:18 PM
jg96powerstroker
16
Oct 22, 2013 09:22 PM
kweiss
Dec 19, 2012 07:12 AM
ChugginAlong
Mar 5, 2012 08:21 PM
dbrugger
Jan 6, 2009 07:32 PM
