I am looking for a few pictures of the ebrake assembly located on the outside of the frame rail to use as a reference.
My ideal replica would show an extended cab, long box 2wd truck.
I need a few pictures showing any of the ebrake equalizer and springs involved, and the line running up the frame as to how/what guides it up to the front cab mount passage. My new brake and fuel line clamps may have stolen the original holes.
If you have any pictures on hand, I would appreciate it.
I have never really looked on an extended cab variant but on my standard 133" bed, I don't
recall there being anything that guides it per say, it goes through a hole in a bracket is about
all I remember for certain.
Here is a pic I took in a JY some time ago:
Here is some stuff from the Parts Catalog, notice it doesn't differentiate body styles or even
F-Series from Broncos, they're all the same 1980-89:
Thanks ctubutis - your picture clears up the spring, and the illustration helps with the cable routing before the equalizer, especially the clamp on inset D.
I think I recall a pigtail eyelet type guide between the equalizer and front cab mount - but it has been over two years since disassembly. I'll mount the equalizer now and pick up/fab something in the line of fire.
