Thinking about using this ebrake set up - any thoughts?
Old May 11, 2016 | 03:42 PM
Don Vito's Avatar
Don Vito
http://www.lokar.com/product-pgs/eme...op-ebrake2.jpg
I think it'll look good, may have to buy their cables & connectors also though..Go big or Go Home I guess.
Don
Old May 11, 2016 | 04:32 PM
HILLBILLY BOB's Avatar
HILLBILLY BOB
I cant bring it up
Old May 11, 2016 | 04:43 PM
ulfie's Avatar
ulfie
In my opinion, the release handle looks a little small and might be difficult to grasp.
Old May 11, 2016 | 05:24 PM
toby tough's Avatar
toby tough
Looks nice, ditto on the handle.
Old May 11, 2016 | 06:52 PM
artscott61's Avatar
artscott61
Veteran: Navy
looks ok to me but then I use pliers to pull everything. Seriously if it is working good and lubed correctly it should not be a problem. I really does look good.
Old May 11, 2016 | 07:23 PM
52 Merc's Avatar
52 Merc
The release **** is fine. No different than a headlight switch, really. Here's my 2c, fwiw. Lokar makes some great products. Their shifters and linkage kits are top notch and they make things no one else does. But imho, unless they've been greatly improved over the years, I'm not a fan of their e brake unit. There's a lot of force put on the cable attachment point from your foot vs. the energy needed to set the brake. The cable ends are just a block with set screws, no different than the throttle linkage but on a slightly larger scale. They slip. Period. No amount of tightening the allen screws will hold the cable sufficiently. Check into it closely if you're seriously considering it. Of course, ymmv. Again, just my opinion, but based on experience.
Old May 11, 2016 | 07:58 PM
41505379's Avatar
41505379
This E-brake looks like one that released all at once. It wouldn't be good for a stick shift vehicle. With a stick shift and clutch its best to be able to release the brake as the clutch starts to engage.
Our 79 Bronco has that type of E-brake release with a stick shift.
Oh yeah! I forgot the most important part: you can not put the brake on while you hold the clutch down. So imagine a steep hill start, with someone close to your trailer hitch, and maybe your wife driving. It's not a good E-brake to have with a stick shift.
Old May 14, 2016 | 12:57 PM
petemcl's Avatar
petemcl
I don't know what truck you are using this on but personally I like the stock handle under the dash on my '50 F2. 41505379's comment about not being able to use that brake and the clutch at the same time to start on hills is certainly valid. Lokar makes nice stuff but pricey.
Visseroth
Sep 2, 2009 09:22 PM
TheWiz427
37
Dec 29, 2007 11:13 AM
frnkln2003
May 10, 2007 02:10 PM
BigF350
General Automotive Discussion
Nov 18, 2006 10:19 PM
