Bronco II Ford Bronco II
Need 2wd Tranny
Old Mar 12, 2003 | 04:13 PM
donk812000's Avatar
donk812000
Exclamation Need 2wd Tranny
Need Affordable A4ld Automatic Tranny With Dummy Transfer Case For My 89 Bronco Ii-2.9-2 Wheel Drive.
My Is No Good, Bell Housing Is Crack, Don't Know About The Inside.
Any Suggestions?
Old Mar 16, 2003 | 10:02 PM
CustomChrome's Avatar
CustomChrome
Need 2wd Tranny
Any 4x4 trans will work. You just have to bolt up your dummy case to it.
Old Mar 19, 2003 | 09:21 PM
LilBronc's Avatar
LilBronc
Need 2wd Tranny
Any 2.9, 3.0, 4.0 A4LD 4x4 tranny will work. The 2.3 have a different bellhousing bolt pattern.
Old Mar 20, 2003 | 03:58 PM
matthews_56's Avatar
matthews_56
Need 2wd Tranny
Find a bell housing in a bone yard, replace the front pump and torque converter to be on the safe side and run it. This is said assuming that the tranny was working before the bell housing cracked. The crack could have taken the tranny out of alignment which will mess up the front pump. In turn that will mess up the torque converter. Total cost will more than likely be under $300. I just had to do this to my tranny (for different reasons) and I spend $250 on the front pump and TC.
trumsey07
Apr 17, 2011 11:35 AM
duback66
May 2, 2004 01:02 AM
magic_man77
Dec 2, 2002 06:27 AM
60f100trk
Mar 28, 2001 12:09 AM
