98 5.4 Stalls
Old Feb 20, 2011 | 06:39 PM
Icefan71's Avatar
Icefan71
98 5.4 Stalls
MY 98 EB 5.4 4x4 started tonight, then stalled after about 3 seconds and the theft light was flashing. It didn't stumble or anything, just died. Then it cranked, but would not start. Tried again and it cranked but didn't start. Third time I turned the key all the way off, then it fired right up. The wife says it has done that a few times over the last few months. I tried to get more detail out of her, but thats all she could remember. The last time I had a starting problem, it was the IAC valve, but the truck would start and immediately die. That was over a year ago. This time it ran for a couple of seconds then died. There are no other symptoms. It drives fine otherwise. Anyone have any ideas?
Old Feb 20, 2011 | 08:14 PM
smac22's Avatar
smac22
Sounds like the transponder in the key. The ignition may not be picking up the key when its inserted. The vehicle will just sit there and crank with a no start like you mentioned. It will also flash the theft light rapidly. If you have another set of keys, try that first for a few days and see if that cures the issue.
Old Feb 21, 2011 | 09:50 AM
Icefan71's Avatar
Icefan71
I can swap keys, but it only happens once in a while. So I don't know if that is the problem. For now I guess I can give the wife my keys and see what happens. Thanks smac22
bthr22
Nov 19, 2014 12:22 PM
Scndsin
Escape & Escape Hybrid
Apr 29, 2013 11:02 PM
Firefighter 1406
32
Aug 2, 2011 02:08 PM
BFTUFF
1997 - 2003 F150
Jul 14, 2011 07:44 PM
aa767man
Oct 10, 2007 08:36 PM
