1978 - 1996 Big Bronco
Obd Ii
Old Oct 21, 2006 | 09:10 PM
BOB ROSS's Avatar
BOB ROSS
Obd Ii
can i use a OBD II code puller on a 95 bronco? and can i get a fair one for about 100 bucks?
thanks for the help.
Old Oct 23, 2006 | 08:47 AM
Kemicalburns's Avatar
Kemicalburns
no you cant use and obd-II scanner on a 95. www.fordfuelinjection.com will show you how to pull codes on your 95 with out a scanner.
Old Oct 23, 2006 | 08:56 AM
BOB ROSS's Avatar
BOB ROSS
thanks kemicalburns
good thing that i didn't lay down 150 bucks for that scanner
Old Oct 24, 2006 | 08:25 AM
Kemicalburns
yea no kidding those scanners can be spendy. also any parts store can scan codes for you as well for free.
Old Oct 24, 2006 | 11:37 PM
Bimmerboy1989's Avatar
Bimmerboy1989
the reader at the store where I work is both OBDI and OBDII. It runs around $200 for it. The "cheap" OBDII code reader only reads some OBDII codes. I really like having an older ford truck because of the self test feature. It;s really nice. But you can get a ford OBDI reader for around $30 if you have to have a reader. They are available at any parts store.
Old Oct 25, 2006 | 01:13 PM
BOB ROSS's Avatar
BOB ROSS
thank's for the replys guys
i needed the scanner for my girlfriends 2002 camry. so i was thinking that i would get one that i could use on both the bronco and the camry, but the price for one that reads OBD II and OBD I was just alittle too much. so i got the local auto store to pull the codes for me. get the stealer to pull the codes for you and it runs about $50.
it would be nice to have one the tool box to use whenever i wanted.
thanks again.
Old Oct 25, 2006 | 06:32 PM
broncobob's Avatar
broncobob
Bimmerboy1989 is right on the cheaper OBD2 readers not reading all the codes. I've got one, works great most of the time, but I found that it wouldn't read transmission codes from my daughter's 96 Contour. The OD light was flashing, so I new there was a code, but the reader said it had no codes. Local garage had a Snap-on reader, got the code with no problem.
shorebird
Computer Chips & Tuners
May 18, 2009 02:24 PM
Skarr
1983 - 2012 Ranger & B-Series
Jan 9, 2008 01:02 PM
kawa
Nov 6, 2007 10:13 PM
fordtrucksforever
Jun 1, 2007 08:21 PM
meck1
May 11, 2007 04:42 AM
