water pump ??
Old Feb 20, 2011 | 01:44 PM
BIG J82's Avatar
BIG J82
water pump ??
will a 97 water pump fit in my 95 ??
Old Feb 20, 2011 | 01:52 PM
84-250's Avatar
84-250
yes but you would need to change the thermostat to a short stem. And the heater bypass tube need to be changed cause of different threads.
Old Feb 20, 2011 | 02:18 PM
RRranch's Avatar
RRranch
What he said. They fit just fine but make sure you use the 97 thermostat and that bypass pipe may not come with the new 97 pump. FWIW, if you get a new 94 pump the factory Ford thermostat is a more desirable temperature. 203 versus 195 for the 97.
Old Feb 20, 2011 | 02:44 PM
tjbeggs's Avatar
tjbeggs
Yep like they said it will but uses a different design thermostat and the heater hose fitting is different. To be honest with you, keep the water pump for the 95 then you can use the 203 degree thermostat from any parts store. I swapped my 97 to a 95 water pump.
Old Feb 20, 2011 | 03:40 PM
BIG J82's Avatar
BIG J82
Thx guys .. I already have the 203 stat ... Where can I get a new neck for the pump?
Old Feb 20, 2011 | 04:10 PM
RRranch's Avatar
RRranch
I know oreilleys carries a murrey brand one but I had to weld up pinholes in the last two I got. It wasn't an option just taking them back for return really. I'd recommend the Ford dealer just to be safe. Although the murrey brand does have a thicker flange. I've had one of them off a couple times now and no leaks there so that part is nice.
Old Feb 20, 2011 | 06:59 PM
BIG J82's Avatar
BIG J82
I think I'll just make my own
