aftermarket headlights
Old Feb 20, 2011 | 01:56 PM
78ecf250cs's Avatar
78ecf250cs
Hey guys im looking at installing a set of aftermarket headlamps on my 99 expedition xlt. The ones im look at take two bulbs a 9007 and a 9005. My factory lamps only have one bulb the 9007. I was wondering if anyone has put on a set like this and what they did to wire the second bulb in. Any info would be helpful, thanks
Old Feb 20, 2011 | 02:22 PM
n5926g's Avatar
n5926g
If possible,post a link to the lights....Maryville Tennessee?
Old Feb 20, 2011 | 02:33 PM
78ecf250cs's Avatar
78ecf250cs
http://cgi.ebay.com/ebaymotors/DEPO-...item4aa8ca0ad8
here is the link and yes Maryville tn
Old Feb 20, 2011 | 02:40 PM
n5926g's Avatar
n5926g
My Mom and Dad live in Maryville....anyway,I took a look at the link,and figure your OEM headlight buckets use one lamp for both High and Low beam.
These(as you stated) have two lamps. From what I can tell,youll need to go to a salvage yard and pick up some sockets.Wiring them should be a breeze. Otherwise you could keep looking for some aftermarket lamps that only use the one lamp.
Unless you are "electric savy" id suggest the latter of options.
Old Feb 20, 2011 | 02:59 PM
78ecf250cs's Avatar
78ecf250cs
That's pretty much what i had in mind.
Old Feb 20, 2011 | 03:12 PM
n5926g's Avatar
n5926g
If you ultimately decide to go with the two lamp model,let me know.Ill give you a few pointers on how to seperate the High/Low beam circuits.Pretty much a no brainer....
Old Feb 20, 2011 | 03:17 PM
78ecf250cs's Avatar
78ecf250cs
That's what I will probably put in it shouldn't be hard just have to find a vehical that uses the 9005 lights.
Old Feb 20, 2011 | 10:17 PM
fordno1's Avatar
fordno1
You could also try parts stores - Napa, Oreilly's something like that. Most of the time they carry replacement headlight sockets. If they don't, they can order. Save you the time of chasing through a salvage yard. My guess is they are about $10 each. Here is a link to Amazon.com for a 9005 socket.
Amazon.com: 3A Racing 46-9995 Heavy Duty Headlight Socket 9005: Automotive
Post some pictures of the headlamps installed. I have been looking at those same ones and not sure if I like how they look. Good luck.
Sparkplugless
Nov 2, 2012 12:17 PM
eatont9999
32
Oct 19, 2011 10:03 PM
Brad2296
Electrical Systems/Wiring
19
Jan 6, 2011 05:47 AM
murph1
1997 - 2003 F150
Apr 13, 2008 09:31 PM
brian42
Oct 30, 2007 01:22 PM
