After tons of research lots of reading and plenty of thought I feel I have come up with a decent build. Please keep in mind I do relize that many of the mods in this list will not agree with the factory ECU and I plan to take care of that with tuning. So dont be concerned with that. Please let me know what everyones opnion is of it. If anyone has a rough idea on what it should produce please inform me.
Comp Cams High Energy 268H Cam
Comp Cams High Energy Lifters
Comp Cams High Energy Push Rods
Comp Cams High Energy Steel Rocker Arms
Sealed Power Hyperteutetic Pistons 4.030 or 4.040 Bore
ARP Connecting Rod Bolts
Sealed Power Main Bearings
King Engine Bearings
Sealed Power Cam Bearings
Melling High Volume Oil Pump
Melling Oil Pump Driveshaft
Melling Oil Pump Screen ***.
Fel Pro Gasket Set.
OEM Ford Head Bolts
Will also be replacing the injectors and complete ignition system (Plugs,wires,etc)
The head will also get a complete P+P and valve job.
Now I do have 2 parts Im not sure if they will work in the 93 or not. Any input on these would be great.
Comp Cams Inline Engine Gear Set Part # 3224 SI Valves, Valve Springs 1.94 Intake 1.6 Exhaust
If anyone has anything I should toss into the mix please let me know. I do relize some of the things rockers,push rods, etc dont haft to be replaced just feel if Im going to take the time to replace most of the parts I might as well replace those also. Sorry for the long post.
Please do not give me the info of use a Clifford Intake and Holley carb......it will be staying FI
Reason: Extras
