electric fuel pump
Old Nov 17, 2001 | 02:08 AM
cobrajet's Avatar
cobrajet
electric fuel pump
Old Nov 18, 2001 | 05:53 PM
mike460's Avatar
mike460
electric fuel pump
hey guys, i have a 460 that i am buildin, and i have a holley electric fuel pump that i am gonna use to fuel the beast. the question is, how do i need to run the fuel line? it is set at 7 psi at the pump, so it says i dont need a regulator, so do i need a return line? or can i just run one line from the tank to the pump to the carb(with a filter before and after the pump), or do i need the return line, too? and if i do, what do i need to make one? thanks,
mike
Old Nov 18, 2001 | 06:36 PM
jbhf250's Avatar
jbhf250
electric fuel pump
I have a "Holley" RED fuel pump. I have 2 tanks. Each tank has its own filter BEFORE the fuel solenoid. Then I feed the pump. Its mounted Under the cab for convenience to the tank lines and soleniod. Then i go to the steel factory line along the frame. From the (engine end)frame line i have a `Clear filter` then fuel line to the carb. Edlebrock 1406. I have the filter down low so if i have a leak it will not go to the hot manifold, and it stays FULL!!
I have no need for a return line. 1972 vintage F250
__JOHN__ô¿õ
1972 F-250
ICQ# 6030753
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
