headers???
Old Feb 19, 2011 | 08:57 PM
Arigg217's Avatar
Arigg217
headers???
Does anyone make headers for the inline 6?? I want to replace the stock manifold and get rid of the heat riser thing, unless I need it.
Old Feb 19, 2011 | 09:13 PM
OrFordGuy's Avatar
OrFordGuy
check on JBL they used to make a dual exit header for the 300ci..
Old Feb 19, 2011 | 09:29 PM
spurredon's Avatar
spurredon
Clifford makes a bunch of stuff for those engines!
Old Feb 19, 2011 | 09:52 PM
dyingtolive's Avatar
dyingtolive
I wouldn't trust Clifford Performance products anymore. Not after some of the things that I've heard about them. Check around on here and on fordsixperformance.com and see what they have to say about the newer Clifford Performance products.
However, Hooker and Hedman Hedders also make headers for the 300.
Headers - Headers - Exhaust - Ford inline 6-cylinder - 4.9L/300 - FORD - SummitRacing.com
Old Feb 20, 2011 | 08:52 AM
Pkupman82's Avatar
Pkupman82
I am running Hedmans on my 84 F150 with a 300 six. I know Clifford headers tend to be a bit pricey, IIRC I think I paid around $160 for the Hedmans from Jegs.
Old Feb 25, 2011 | 04:27 AM
nchapman2's Avatar
nchapman2
Does putting headers on the 300 make i big differents.
Old Feb 25, 2011 | 05:01 AM
dustybumpers's Avatar
dustybumpers
headers make a big differance. make sure you have a new starter on, you'll not be able to change it later. use mr gasket 260 gasket, all others leak. there is an I6 forum on here, you might want to check it out
Old Feb 25, 2011 | 12:12 PM
nchapman2's Avatar
nchapman2
Id never seen a set before. They would have to make a big differents. to bad about the starter though. the rebiulds dont last forever.
Old Feb 25, 2011 | 02:29 PM
spurredon's Avatar
spurredon
That's a nice looking engine!
Old Feb 25, 2011 | 04:05 PM
dustybumpers
Thanks. that's my 82.
Old Feb 28, 2011 | 01:09 PM
Arigg217's Avatar
Arigg217
What carb do you have on there?
Old Feb 28, 2011 | 02:06 PM
dustybumpers
600 holly on a offenhouser " C " manifold
Old Feb 28, 2011 | 02:12 PM
Arigg217's Avatar
Arigg217
Did you have to get a new fuel pump for it? How hard was it to tune the Carb for the 300?
Old Feb 28, 2011 | 02:19 PM
dustybumpers
I put a new fuel pump on, only because I rebuilt the motor. the one I put on is a stock off the shelf replacement. airtech I think. I got lucky on the tune, out of the box, and on the motor, nothing more than idle air adjustment. Some guys are not so lucky, and have to do quite a bit of tuning. Maybe mine worked out because I ported and polished the head, IDK
Old Feb 28, 2011 | 06:47 PM
spurredon's Avatar
spurredon
Nothin' wrong with being lucky!
