Modular V10 (6.8l)
Ignition coils
Old Feb 19, 2011 | 02:08 PM
Kennicol's Avatar
Kennicol
Ignition coils
I have a 2001. Will the ignition colis make the check engine light come on if there is anything wrong with them. The truck runs good am going to take a trip and was checking everything out I didn't want to pay a shop to check them out if nothing is wrong or if the check engine light would come on if something was wrong with them.
Old Feb 19, 2011 | 03:11 PM
Kennicol's Avatar
Kennicol
Ignition coils
Will a Faulty ignition coil or any problem with one set of the check engine light
Old Feb 19, 2011 | 03:38 PM
jh818's Avatar
jh818
Indirectly, it will trigger the CEL. It will cause fuel from being burned and trigger a sensor in the exhaust.
Old Feb 19, 2011 | 07:18 PM
BigPigDaddy's Avatar
BigPigDaddy
Check here.
Old Feb 20, 2011 | 08:18 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Do you already HAVE the check-engine light on, or are you just asking about it?
The simple answer is MAYBE.
Old Feb 20, 2011 | 12:44 PM
knightrider955's Avatar
knightrider955
I was wondering the same thing today when I was thinking about changing my plugs. How would you know if one of the coils wasnt working?
Old Feb 22, 2011 | 11:00 AM
Kennicol's Avatar
Kennicol
just asking about it. the check engine light isn't on.Was thinking about having tech hook computer up to check them but if they kick on the check engine light on.Don't see any reason to spend the money to check them.
Old Feb 22, 2011 | 07:07 PM
SDV10's Avatar
SDV10
99.9% of the time, you will get a light telling you something is wrong. Code reader will tell you what, most of the time. If a coil is bad it will show.
Old Feb 22, 2011 | 09:13 PM
jndinmo's Avatar
jndinmo
If you have a bad coil you will know it, it will run like crap whether your check engine light is on or not. So to answer your question if the truck is running good and the check engine light is on you may have another problem but it's not a coil.
Old Feb 23, 2011 | 07:29 AM
krewat's Avatar
krewat
That's not always true, and almost NEVER true with the OBD-I V10s.
Old Feb 23, 2011 | 09:02 AM
SDV10's Avatar
SDV10
Sorry, I sit humbled. In my experience the computer tells of miss fire and tells which cylinder if you have a code reader. However, On the trucks i have worked on, (mostly 97-04 v-8 and v-10's), The cell has not come on before I fix them. The customers have told of running like crap and I see the 'pending' code and not a light. Maybe the light would never have come on. Again, sorry, I sit here humbled. 99.9% is a ridiculous number also.
Old Feb 23, 2011 | 09:05 AM
Kennicol's Avatar
Kennicol
no problem sdv10
Old Feb 23, 2011 | 09:49 AM
krewat's Avatar
krewat
Sorry, I sit humbled. ...
Not a problem, man... from the Tech Folder:
https://www.ford-trucks.com/forums/5...t-come-on.html
The V10 in most F-series that are over the 8500lbs at the time of manufacture, do not need to adhere to the OBD-II standards of emissions controls.
So, while not strictly required by the OBD-II standard, I still don't get why Ford did it this way. Maybe to keep the warranty claims down
ugh3012
Modular V8 (4.6L, 5.4L)
May 22, 2016 06:40 PM
Spaznaut
Electrical Systems/Wiring
Jul 26, 2015 10:39 AM
Spaznaut
Jul 13, 2015 09:56 PM
3trucks
May 24, 2006 11:23 PM
