Better inline six?
Old Mar 12, 2003 | 12:11 PM
rock_axe's Avatar
rock_axe
Better inline six?
i have a 1994 f-150 with 300 inline six, it gets 13 miles to the gallon and the engine runs very smooth, but i was looking for advice with gear or even tranny swap for less rpms on the interstate any ideas ?
Old Mar 12, 2003 | 12:20 PM
gdavis2265's Avatar
gdavis2265
Better inline six?
Give us some specs on your rig. Tire size, gearing, driving style, towing, etc...
Old Mar 12, 2003 | 09:37 PM
Budly's Avatar
Budly
Better inline six?
I also have a 94 f-150 auto I6. I get about the same mileage but i A) have over sized tires B) haul *** everywhere and C) need to clean my injectors, replace fuel filter, air filter and oil change which should improve the mileage sum. People tell me to take the big tires off and i tell them where to go. If i can drive a V8 it might as well look like i am, my ride looks like it is carrying a 460 as a 3/4 ton
Old Mar 16, 2003 | 09:34 AM
broncr's Avatar
broncr
Better inline six?
lower rearend gears or larger (diameter) tires will get you lower rpms but I've been dissapointed in the past with net change in mpg's. Which are you after... lower rpms or better mpgs?( I know... "BOTH - BOSS"....) For mpgs, I'd suggest starting under the hood instead of the body. Need to know your specs (dif. gear ratio, tranny and tire size) for the rpm changes
Old Mar 16, 2003 | 02:47 PM
mantta's Avatar
mantta
Better inline six?
I have a 1988 F-150 XLT Lariat, 4.9, AOD, 3.55 gears, short bed and I get right around 20 MPG on the highway and 17-18 city driving. I have the standard size 235x15 tires on it.
Old Mar 23, 2003 | 12:12 AM
rock_axe's Avatar
rock_axe
Better inline six?
i have standard size tires i have axel code 19 whick i believe is 3.55's i have manual 5 speed tranny i am looking for lower rpms, which hopefully could result in better mileage but i really want better gas mileage and maybe more horsepower under the hood to pull the gears if a gear change is a good i deaa
pdewitz
Computer Chips & Tuners
Nov 20, 2004 01:15 PM
RetroF-150
Aug 2, 2004 05:20 PM
bcsbadboys
Apr 23, 2002 12:31 PM
paulg
Mar 9, 2001 12:30 PM
David
Jan 30, 2000 07:33 AM
