Sponsored by: Real Truck
Power Steering leak
Old Feb 18, 2011 | 06:55 PM
Shadyluke's Avatar
Shadyluke
Power Steering leak
I have a 2003 6.0L that has developed a pretty nasty leak. It it leaking power steering fluid (ATF) from the Master Cylinder. I degreased everything under there and ran it a bit. It doesn't appear to be coming from a line or fitting. Has anyone had any issues similar to this. I haven't had much luck searching the web or here about this one.
Thanks,
Luke
Old Feb 18, 2011 | 10:28 PM
Csticks's Avatar
Csticks
I have the same problem with my 2003 Ford 6.8L. I actually just found it so i havent had a chance to do anything with it...I would check the cap if anything, but you said its from the master cylinder right?
Old Feb 19, 2011 | 06:08 AM
projectSHO89's Avatar
projectSHO89
The master cylinder can't leak ATF since it only has brake fluid in it...
Old Feb 19, 2011 | 07:49 AM
Shadyluke's Avatar
Shadyluke
The booster is hydraulic that is run off of the power steering pump. The power steering pump uses ATF. Sure can leak ATF.
Old Feb 19, 2011 | 04:57 PM
projectSHO89
Okay, must be something different from the older gassers I have. I missed the diesel part. Thanks for the correction.
johnstonmatt77
Sep 2, 2014 12:54 PM
1992FordF150Custom
Jul 6, 2014 03:31 PM
raptor131
Sep 15, 2013 08:48 PM
1Saint
Dec 21, 2009 07:39 PM
castledrummer
May 2, 2007 02:59 PM
