My rear pass window on my '02 explorer quit working, i pulled it apart and found the 2 cables in the regulator/motor assembly were all chewd up, i think i solved the problem to fix that, now I am wondering does anyone know where I can get the plastic clip that is on the bottom of the window rivited on? I was looking at the driver side and that clip is also breaking, hope someone maybe sells just that clip.
You're probably going to need to purchase new window regulators to get that clip. I've searched for the nylon pieces for other Fords and never found a source.
O'Reilly Auto Parts is starting to stock many window regulators for a much reduced price versus OEM.
Thank You, i figured no one would sell just the piece i need, gotta love it!
Does anyone know if 2002 is different than 2003 and newer, i found the regulator on rockauto saying it fits my 2002, but when i looked up the part number on the mfg website it says 2003 and up, I wanna make sure they didnt change anything for that year and i get the right part.
When I bought my door lock actuator from Rockauto I spent so much time comparing numbers and photographs between Rockauto the Ford to make sure I was getting the correct part. And even then when I received the actuator is was "slightly" different and not exact. Even the door ajar switch came with a different stamped on Ford number than the original part yet when I research the cross-reference found it will work.
Sitting at the computer with a couple of beers should eventually figure this out... it did for me.
