Dipstick?
Old Feb 18, 2011 | 02:25 PM
bestbuymudder's Avatar
bestbuymudder
Dipstick?
Ok so im sorry for making anoth thread but i couldn't find one on this topic. i just did an oil change & put in roughly 5.5 quarts of oil. My dipstick says its near empty. ive ran it probably 5 minutes or so. Also can someone post a link of how to rebuild a 2 barrel carb. My engine is the 351m/400. thanks guys
Old Feb 18, 2011 | 02:40 PM
704 dentside man's Avatar
704 dentside man
What do you mean your dipstick says it's near empty? If there's any on the dipstick at all, it's definitely not empty. Also you should be able to hold 6qts...or more if it's an extra capacity pan.
Old Feb 18, 2011 | 02:41 PM
bestbuymudder
There's some on the dipstick not a lot though should I run it longer?
Old Feb 18, 2011 | 03:04 PM
704 dentside man
Well first you said you only used 5.5 qts, instead 6, and I don't think you're accounting for oil filter capacity either...so I'm willing to bet, you're gonna be low regardless. As for running it longer????? Not sure what that would accomplish?
Old Feb 18, 2011 | 03:06 PM
bestbuymudder
Ok is it ok to run today I gotta go to work. And also do you guys know of any instructionals of how to rebuild a motorcraft 2150 for a first timer
Old Feb 18, 2011 | 03:13 PM
704 dentside man
A half quart low...yeah it'll be fine to run, I've run em 4 qts low before, and after about a 120mile drive, the temp started to spike in ATL at about 3am...that was fun. As for the carb, instructions should come with the kit, but it's really not difficult, especially if you lay things out in order of the way they came out.
Old Feb 18, 2011 | 03:15 PM
78 PEB's Avatar
78 PEB
Why in he** would you run 4 qts. low????? Stop and buy some oil...................
Old Feb 18, 2011 | 03:38 PM
704 dentside man
Trust me, neither time was intentional...one time was a buddy's rig, poorly maintained and it wasn't until it was overheating that I realized it needed oil. The other time, when I had to stop in ATL, it was one of my trail rigs...no way should it have been on the street, but it licensed and registered...I was on my way back home from a romp on a buddy's property...and with an engine that uses more oil than gas, sometimes you lose track of when the last time you topped off oil...and when you ask a buddy to check and he says you're good, but he forgot to check, it leads to overheating in ATL at 3am, with 3 hours left in your trip.
Old Feb 18, 2011 | 03:48 PM
Thunderbird7480's Avatar
Thunderbird7480
Like a lot of them, mine leaks some oil. I usually add when its about 3/4 low. I would really rather not go a quart or more
Pheadrus
Dec 30, 2013 07:53 AM
khakushia
Nov 26, 2012 08:45 AM
skibender
Feb 13, 2007 09:34 AM
luke_trash
Jul 11, 2003 09:04 AM
swenson
1978 - 1996 Big Bronco
Jun 8, 2003 06:20 PM
