Inside window seal
Old Feb 18, 2011 | 11:24 AM
DIYMechanic's Avatar
DIYMechanic
Inside window seal
The seal on the bottom of the inside of my window won't stay in place because the PO broke all the little plastic tabs off that it fastens to. The seal and weatherstripping has small "teeth" on clips that as best I can guess are designed to grip onto plastic tabs that protrude from the inside door skin. these tabs are all broken off and gone. My question is this, is there another way to get the weatherstripping and seal to stay in place other than replacing the inside door skins?
Old Feb 18, 2011 | 12:34 PM
redlightning93's Avatar
redlightning93
The best fix for this issue is to use pop rivets through the seal and door panel. It will require three for each one and you will need to use short ones to prevent intrusion into the inside of the door. I have repaired several this way and it works out fine.
Old Feb 18, 2011 | 01:04 PM
DIYMechanic
Ok, so you pop-rivet the seal to the door panel? I am assuming you take the door panel off and do this from the inside somehow, or do you do it from the outside? Any pictures would really help. Do the pop rivets show on the outside of the door panel then?
I am a bit confused.
Old Feb 18, 2011 | 04:57 PM
redlightning93
You will need to pull the door panel and pop rivet the seal to the door panel. I do not have any pics to send but once you get the door panel off you will see that it is not hard to understand how to do it. I used 1/8" rivets and also used a 1/8" washer on the panel side so the rivet would not pull through the plastic. The rivets will never show when done this way.
Old Feb 18, 2011 | 05:50 PM
DIYMechanic
Sweet. I think I understand what you're talking about. I'll have to pull my door panels off and give it a shot some time soon.
Thanks for the help!
Old Feb 18, 2011 | 07:10 PM
Encho's Avatar
Encho
The Southernmost Mod
Well, when someone does it please send some pics this way?.
tolliewolly
6.7L Power Stroke Diesel
Aug 13, 2014 04:27 PM
four-sixty-power
18
Jul 30, 2011 12:17 AM
reflections
Jun 22, 2009 03:22 PM
