Factory gauge malfunction?
Old Feb 17, 2011 | 11:18 PM
Midwest Dually's Avatar
Midwest Dually
I am wondering if anyone else has faced an issue involving the gauges in our trucks.. I have an entire side of the faactory gauges not operating correctly. The engine temp, oil pressure, volt and gas gauges.. they run a full sweep to the opposite end and pegged out beyond where they would normally rest, and remain there while running. Is there a specific circuit I need to check?
Old Feb 17, 2011 | 11:35 PM
BadDogKuzz's Avatar
BadDogKuzz
It sounds like a bad fuse or bad ground. Check your fuse first. Then check the back of the dash panel itself for ground or contacts where it plugs in. Do you have all your dash lights working?
Old Feb 18, 2011 | 12:21 PM
Midwest Dually
I will check the fuses and ground.. As for the lights working, everything lights up, EXCEPT, lol, the odometer (which remains blank) and the dually fender clearance lights. I wonder if I missed a wire on the fenders though..
lud04X
Jan 2, 2012 02:36 PM
Storm
Mar 9, 2010 10:27 PM
riverrat41
16
Sep 15, 2009 11:39 AM
mosgo1
Electrical Systems/Wiring
Nov 19, 2008 08:02 PM
Dog_Brains
Jun 28, 2001 11:37 PM
