brake master cylinder
Old Feb 17, 2011 | 08:10 PM
broozerthehoundog's Avatar
broozerthehoundog
I did a sas last year . An 89 dually front end D60 kingpin ,replaced my TTB50 on my 96 F250. Swapped over hubs and all that junk.
My question is ,I have never had really great front brakes like I used to, so should I of changed to the older style master c . The new (older) D60 has 2 cups in each caliper and the old calipers(96) had one.
And yes they were bled correctly ,over and over ,without any change.
Anybody who has actually done this have comments, recommendations?
Don't want to buy a master c that's not going to change anything.
Thanks
Jim
Old Feb 17, 2011 | 10:41 PM
cj06's Avatar
cj06
looked at autozone to compare master cylinders and your truck could have ones with a 1 1/4" bore and it looked liked the older ones had a 1 1/8" bore ! dumb question but how is the rear brakes working ?
could you swap the original calipers on the front and then it would be just like what it was ?
if you did replace master cylinders the old one mite not work properly because they where set up for drums on the back !
Old Feb 18, 2011 | 04:54 AM
broozerthehoundog
My rear brakes are perfect. ABS works . That has to be the problem. The fronts work, just not well. The other calipers were bolt on and these are slides ,so going back is not an option. I guess I'll get the master c off the old truck and measure it up.
Thanks
F-250 restorer
17
Aug 6, 2011 06:12 PM
jimi
Aug 8, 2007 02:54 PM
Jim Hughes
Jan 28, 2007 07:37 PM
77_F150_4x4
Apr 28, 2005 12:22 PM
walnutcreek
Mar 8, 2005 02:01 AM
